22-11-2007, 12:09 AM
At Learning Steps
Can't figure out the problem, help required!!!
I have an intel celeron 1.0 ghz pro. with intel 810 chipset mother board, and 2 128 mb ram (133mhz), i have installed xp sp2.
Now the prob is that whenever i try to rewrite any file (maybe any image or word docu.) by saving it, the system gets restart.
I had tried reinstalling xp that couldn't solve the problem. thinking now it maybe some hardware prob.
HELP REQUIRED!!!!
22-11-2007, 12:11 AM
Re: Can't figure out the problem, help required!!!
maybe your RAM is going bad.. try running your computer on a single chip, try to install the first chip then run your comp and then the second one.. this way both your chips will be checked..  , if this is not the case then check your SMPS..
22-11-2007, 12:14 AM
try to reset your BIOS by removing the CMOS battery and the jumpers for few minutes and then reboot with default settings.
22-11-2007, 12:21 AM
At Learning Steps
i had checked with the ram but the prob. still exists, it shows a full 256 mb of ram when installed with 2 ram, how do i check the spms fault.
22-11-2007, 12:27 AM
i told you to check with single chip  not both of them at the same time.. sometimes one ram is faulty but the comp. works fine coz of the other.. and try to borrow your friends SMPS and install it on your comp. or get a new one for Rs. 350 or so a 400Watt intex or any..  and say the dealer that you will return it if the problem remains the same..
22-11-2007, 12:32 AM
Still Shining!
Yah, try running with one of the RAM. And see if the problem persists..
Nokia N86 8MP
22-11-2007, 12:36 AM
"The Gentleman"
have you connected something to your usb ?
like today when i connected my 40 Gb hdd thru usb then tried to "Empty Recycle Bin" system automatically gets restarted but after removing from usb system works fine. (just incase a sol if u have connected any hardware to usb, remove & recheck)
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
22-11-2007, 10:54 PM
At Learning Steps
i had tried with checking the single ram individually, both the ram are working fine, i had checked with another smps also, neither any usb device is attached to my system, but the problem still persists. next???
22-11-2007, 11:26 PM
If it happens randomly,could be a motherboard problem,which is actually quite common with aging capacitors etc.But before taking it to the local hardware guru,strip down the system to the minimum(no pci cards etc) and observe.
Let there be music.....
23-11-2007, 05:15 AM
The High 5 Flyer
HELP REQUIRED!!!!
I suspect a BAD SECTOR. I'd suggest boot to DOS and run a surface scan on the C drive or any drive on which you are trying to save the file. This could be the issue......
