Old 21-11-2007, 08:03 PM   #1 (permalink)
Default strange problem with CMOS battery
i m having a strange problem.
whenever i put the CMOS battery on the motherboard and switch on the UPS the power led glows, the processor fan revolves for a second or two and then stops & nothing happens and the system does not boot. when i remove the battery all is fine and the system boots with default bios settings.
secondly it happens that my hard disks starts making annoying noises and stops working. hearing the sound gives the feeling that the platter of the hard disk revolves for a second and stops and again after som time revolves and stops. this happens either at system start or in middle of the working after complete boot up. but at other times the whole system works fine.
i m having a intel 915 gav motherboard BIOS updated to 22 feb 2006 p4 3.0GHz HT enabled 512 MB RAM and 80GBPATA+80GBSATA+160GB SATA HDD
this problem is from last 2 months
ondemandemails is offline
Old 21-11-2007, 11:46 PM   #2 (permalink)
Default Re: strange problem with CMOS battery
Get a new cmos battery.
The hdd thing.....does it happen with any one specific drive(out of the 3).If so you may want to backup your data,coz it's on it's last legs it seems.
Let there be music.....
sashijoseph is offline
Old 22-11-2007, 12:06 AM   #3 (permalink)
shantanu's Avatar
also check your SMPS for faults..
shantanu is offline
Old 22-11-2007, 12:10 AM   #4 (permalink)
anand1's Avatar
There may be a fault in your PSU try checking it a new one.
Technology On The Fly
anand1 is offline
Old 22-11-2007, 12:14 AM   #5 (permalink)
shantanu's Avatar
anand : what i said meant the same.. try not to spam the forum with these kind of posts just to increase your post count.. . not deleting your message , so that you remember it the next time.
shantanu is offline
CMOS problem... ComputerUser QnA (read only) 2 17-08-2007 08:28 PM
CMOS battery 56561 QnA (read only) 3 26-04-2007 09:38 PM
RAM or CMOS problem....?? hard_rock Hardware Q&A 9 30-09-2006 03:20 PM
CMOS battery replacement ashu888ashu888 QnA (read only) 4 26-10-2005 07:11 PM
MB's CMOS battery discharge problem sms_solver QnA (read only) 3 12-11-2004 01:42 AM
