Old 20-11-2007, 06:35 PM   #1 (permalink)
Default Why not Intel DP35DP ???
Hello Digisters..
I'm getting a new system this weekend.. Had finally zeroed in on the MSI Platinum or the Neo.. blame it on Digit..
Now, my uncle wants to know why I do not want the Intel DP35DP.. I don't really know.. There's loads of reviews all over the net for MSI boards but not one for the Intel Board.. I do not know what the Intel board is capable of.. Any ideas?
ricky_pradeep is offline
Old 20-11-2007, 07:06 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Why not Intel DP35DP ???
1 main reason wd be that u cant OC wit the intel board..
That defeats the purpose of getting a c2d/q
Pathik is offline
Old 21-11-2007, 10:11 PM   #3 (permalink)
What? Really? Never knew that! Whoa..
Thanks..
Old 21-11-2007, 10:16 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
I think the new boards do support OC'ing.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 21-11-2007, 10:35 PM   #5 (permalink)
Alpha Geek Banned
bikdel's Avatar
^^ like?
(except the 975 ones and the inbuilt 10-15 % burn in mode in some...)
I'm not a GEEk, i still use Windows!
bikdel is offline
Old 21-11-2007, 10:43 PM   #6 (permalink)
Commander in Chief
Just that I guess then, had heard it some time ago.
Harsh J
www.harshj.com
Intel core duo t2450 @2 Ghz or intel dual core @ 1.73Ghz ??????????? arunks CPU / Motherboards 6 04-03-2008 11:54 PM
AMD SELLS INTEL CPUs... HAS IT COMPLETELY LOST THE WAR WITH INTEL C2D vish786 Technology News 9 09-06-2007 07:46 AM
Intel mobo for Intel Core 2 Duo E6300 !! kaps_2222 Hardware Q&A 3 21-04-2007 10:32 AM
Which is best.--->Intel 915P or Intel 915G vps85 CPU / Motherboards 5 20-01-2005 08:57 PM
