Old 20-11-2007, 05:54 PM   #1 (permalink)
Default Motherboard for AMD
Hi,
I am planning to buy Athlon 64 X2 4400+
Which would be the motherboard suited for it under 5k?
Nvidia 6/7 series graphic onboard available for this?
Thanks.
pramodv1988 is offline
Old 20-11-2007, 06:45 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Motherboard for AMD
How about MSI K9AGM2 Or Asus M2A-VM
MSI K9AGM2
2 RAM slots..support upto 4 GB/DDR2 800 MHz
FSB-->>1600-2000 MHz
2 SATA, 1 PATA port
2 PCI slot..1 PCI x1 slot
7.1 audio channel support
1 onboard LAN
4 usb port
1 firewire port
Price-->> Around 3K
Asus M2A-VM
4 RAM slots..support upto 8 GB/DDR2 800 MHz
4 SATA, 1 PATA port
5.1 audio channel support
1 onboard LAN
4 usb port
1 firewire port
Price-->> Around 5K
ravi_9793 is offline
Old 20-11-2007, 07:02 PM   #3 (permalink)
harryneopotter's Avatar
and wat about -->
Asus M2NPV VM
4 SATA, 2 PATA port
2 PCI slot..1 PCI x1 slot..1 PCI x16 slot
1 onboard LAN (GIGABIT)
4 usb port (upto MAX 10 ports)
2 firewire ports
VGA and DVI ports
TV out (with HDTV Support)
Price-->> Around 4300 Rs
harryneopotter is offline
Old 20-11-2007, 07:04 PM   #4 (permalink)
Google Bot
Pathik's Avatar
Asus m2a vm
msi k9agm2
msi k9ngm2
biostar 7050
Pathik is offline
Old 20-11-2007, 07:04 PM   #5 (permalink)
dOm1naTOr's Avatar
MSI K9A GM2 costs only 2.3k
and Asus M2A VM costs only 3k.
Both are ATI 690G chipset based micro ATX mobo.
K9AGM2 dun have DVI, but M2A VM has DVI as well as dsub. Its HDMI version is avalable for 3.5k.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 21-11-2007, 10:54 AM   #6 (permalink)
pushkaraj's Avatar
The price of Asus m2avm hdmi with amd x2 5600+ when i asked two weeks back in lamington road was 11k
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
pushkaraj is offline
Old 21-11-2007, 11:54 AM   #7 (permalink)
Google Bot
Pathik's Avatar
Thats a bit steep @pushkaraj
Pathik is offline
Old 21-11-2007, 12:53 PM   #8 (permalink)
"The Gentleman"
vish786's Avatar
M2A-VM doesnt support super model 3.0, go for M2NPV VM or M2NPV MX (go for one which is cheap.)
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 21-11-2007, 03:07 PM   #9 (permalink)
pushkaraj's Avatar
^^^do u mean shader model 3.0. And asus m2avm has onboard nvidia 7 series graphics. so that wud suit him. or r there any other mobos with onboard 7 series graphics.
Old 21-11-2007, 04:03 PM   #10 (permalink)
Alpha Geek Banned
bikdel's Avatar
??? whats super model 3.0 ?? some kinda girl picture on the POST screen?
I'm not a GEEk, i still use Windows!
bikdel is offline
Old 21-11-2007, 04:05 PM   #11 (permalink)
oh god ......... I missed that super model 3.0
My M2NPV VM shows that ugly logo instead of that SUPER MODEL
Old 21-11-2007, 05:18 PM   #12 (permalink)
dOm1naTOr's Avatar
ill dig out my M2A VM for supermodel...
nyway @pushkaraj
how come M2A Vm has nvidia gfx
M2A itself means....ATI chipset nd M2N means nvidia chipset.
M2A VM has SM 2.0 ATI X1250 GFX which is similar to nvidia's 7050 onboard GFX which is SM3.0. M2A VM can even run crysis at low setings.
G3: XPS M1530 |
FZ 16.
Old 21-11-2007, 11:27 PM   #13 (permalink)
pushkaraj's Avatar
Arrow Re: Motherboard for AMD
Lolzzz...
Oh i think even my mobo gigabyte ga-k8n51gmf-9
Doesn't hav supermodel 3.0
Btw aravind i am a bit confused about the m2avm. I thought it has nvidia 7 series graphics. Then which is Asus's latest offering with onboard nvidia 7 series gfx. And btw, dont be surprised if i say that crysis works even on my mobo that has onboard nvidia 6100 gfx. I have an amd athlon 64 3200+ 2.0 GHz with 512 MB of DDR400 ram. Nvidia rocks What say?
Old 21-11-2007, 11:41 PM   #14 (permalink)
dOm1naTOr's Avatar
@pushkaraj
but ull not get the joy of DRIVER BUGS with nvidia
G3: XPS M1530 |
FZ 16.
Old 22-11-2007, 12:02 AM   #15 (permalink)
coolsunny's Avatar
Originally Posted by aravind_n20
@pushkaraj
wht does it mean... Any problem with M2A VM mobo ?
AMD X2 260, GA M68MT-S2P, Gskill RipjawsX 4GB, 500Gb Seagate, Cooler Master eXtreme Power Plus 600W, Altec Lancing atp3, Samsung B2230 TFT, Numeric Digital 600 EX-C UPS.
coolsunny is offline
Old 22-11-2007, 12:16 AM   #16 (permalink)
"The Gentleman"
vish786's Avatar
Post Re: Motherboard for AMD
for fun purposely said "supermodel" , for others who didnt get, i meant "Shader Model 3.0"
how can ati's SM 2.0 be nvidia SM 3.0 , SM 2.0 Tech is same no matter whether is ati/nvidia dude.
This is from Asus site
AMD 690G
The AMD 690G Northbridge is the latest AMD chipset designed to support 800/1000MHz HT(HyperTransport) interface speeds, Microsoft® DirectX 9.0, Pixel Shader V2.0 and dual VGA outputs including DVI interface. It features the integrated ATI Radeon X1250-based graphics.
Look it says, Only shader 2.0 works on this mobo, even if an external ati/nvidia card with SM 3.0 is used will not be supported.
- Dijkstra
vish786 is offline
Old 22-11-2007, 03:54 PM   #17 (permalink)
i didnt believe u ...then....
i believe u now....man..more higher.......... jumps the more it exposes itself..hide in a corner naa...
and use smilies ..looks like your "jokes" r for "geeks" only..
kanguy is offline
Old 22-11-2007, 05:42 PM   #18 (permalink)
now wat shld i say ..........
Old 22-11-2007, 07:25 PM   #19 (permalink)
Gizmo Freak !
spitfire's Avatar
@pushkaraj
So far ,nVidia driver for vista just sucks...ATi-AMD is doing rather better in this front..
spitfire is offline
Old 22-11-2007, 09:06 PM   #20 (permalink)
dOm1naTOr's Avatar
@spitfire
maybe...but in my opinion ATI sux in drivers. Most of the driver releases are buggy.
I updated X1250's driver from ATI site and it clearly says 'driver for x1250 onboard GFX', but it dun work. But the one given is CD worx fine.
nvidia also started releasing buggy drivers after vista and GF8.
G3: XPS M1530 |
FZ 16.
Better Motherboard vikramkh CPU / Motherboards 5 23-07-2007 12:18 AM
Motherboard for AMD X2 CadCrazy Hardware Q&A 5 23-04-2007 02:21 AM
motherboard pawanranta CPU / Motherboards 2 21-01-2007 09:36 PM
Motherboard parimal_xp2003 CPU / Motherboards 4 22-06-2005 12:05 AM
