Old 20-11-2007, 04:08 PM   #1 (permalink)
Dishant's Avatar
Smile Upgrade my SMPS
hello, members ..this is my first thread...
i hav an asus m2n-vm dh mobo + amd 4200+, 4x1 ddr2 667 mhz Kingston ram+3 sata HDDs + hp dvd + microtek 300 watt smps........i want to know that is my current smps capable for this config. or shud i upgrade.....pls suggest me a detailed upgrade suggestion for smps......i don't hav Antec/CM in my city....
thaks in advance
Dishant is offline
Old 20-11-2007, 04:35 PM   #2 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Default Re: Upgrade my SMPS
Powersafe, Corsair or at minimum Colorsit 450W. That microtek 300W may not be sufficient. Also tell us your budget.
john_the_ultimate is offline
Old 20-11-2007, 04:49 PM   #3 (permalink)
-----ATi-----
nvidia's Avatar
That 300W SMPS will not be enough.
You buy atleast 450W SMPS though 400 will usually be enough for your config
http://twitter.com/akshayms
nvidia is offline
Old 20-11-2007, 05:08 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
300 watt is not sufficient.I will suggest you ti upgrade to any with 450 watt or even higher watt SMPS.
ravi_9793 is offline
Old 21-11-2007, 06:56 PM   #5 (permalink)
Dishant's Avatar
in my area only brands like zebronics, enter and i ball r available......and my budget is 2000
which one shud i opt for?
Dishant is offline
Old 22-11-2007, 12:22 AM   #6 (permalink)
No pain....No gain
Zebronics.
Old 22-11-2007, 01:38 AM   #7 (permalink)
well this SMPS is most probably enough for your needs. Whoever saying it is not enough has very little knowledge about smps.
still follow this link and check ur actual requirements: http://www.extreme.outervision.com/p...ulatorlite.jsp
Point no 1: If you have already bought the psu stick with it if you are not having stability problems. Look buddy Microteck is now something of a stellar performer but unless you don't add a graphics card or use heavy computing that will put your processor on 100% load for prolong periods, this PSU should do fine.
If you want to upgrade atleast get a zebronics 500W platinum if it's available. Zebronics is not a good brand but you can't help it as there is nothing else available.
If you are upgrading, keep in mind that at least 450W is must with minimum 30amps on +12V rails (very important). Even if a PSU is 600W but only have 20amps on +12V rails it's worthless. so keep this in mind. amps on +12V rails is very important.
morgoth is offline
Old 22-11-2007, 05:20 PM   #8 (permalink)
Dishant's Avatar
thank you guyz...thanks you all......for helping me and coz today is THANKSGIVING DAY..........
******* ****HAPPY THANKSGIVING DAY*********
TO EVERYBODY HERE
Dishant is offline
Help meee!!20 pin SMPS to 24 pin SMPS? sourav Hardware Q&A 9 25-09-2006 10:37 PM
AMD system upgrade..err??no u all bored of upgrade forums but pls do help me...!! karthik316_1999 Internet & WWW 11 18-07-2006 08:10 PM
graphic card upgrade(PCI) or motherboard upgrade? thetopcyborg Graphic cards 5 13-01-2006 02:32 PM
Zebronics 500W SMPS. Is it a good SMPS. Advice needed. Yoda QnA (read only) 4 13-11-2004 11:15 PM
- by kool
