Old 20-11-2007, 01:43 PM   #1 (permalink)
Default computer not restarting
i hv gone thru a lot of posts regarding computer restarts instead of shutting down or rebooting unexpectedly when working.
i have a problem that my computer is not restarting. it is shutting down peacefully but when i restart from start>turn of computer>restart it hangs at the message "windows is shutting down"
this is the problem with linux too.
slyfox is offline
Old 22-11-2007, 12:19 AM   #2 (permalink)
shantanu's Avatar
Default Re: computer not restarting
there can be multiple reasons, for some i am not sure , but it might help. try checking your PSU( SMPS)(power supply unit) , then check your jumper for restart on motherboard (it might not help) . also check the BIOS settings for ACPI and power..
shantanu is offline
Old 22-11-2007, 12:38 AM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
try this:
This may help you:
http://www.techhunt.org/node/10
ravi_9793 is offline
restarting computer!!! phanibhushan Hardware Q&A 6 26-07-2007 02:30 PM
Computer Restarting again and again.... Manshahia Hardware Q&A 6 04-06-2007 07:26 PM
Computer Restarting....Randomly..Plz help shyamno Hardware Q&A 9 16-04-2007 11:50 AM
Computer restarting...:( nilesh4u QnA (read only) 13 30-03-2006 11:44 PM
computer restarting automatically dittualex QnA (read only) 1 14-11-2005 12:44 PM
- by kool
