Old 19-11-2007, 03:14 PM   #1 (permalink)
Still in war with allies
ssdivisiongermany1933's Avatar
Default Better Quality on Tv tuner card on cable
Hi
I have leadtek winfast Tv2000 Xp global Tv tuner card ...
and there are three connections at home including Tv tuner card with single cable coming from cable operator ,but the problem is that Tv tuner is not giving good quality , but other two connections are giving qualities on TV ...
What can I do receive better picture quality on My tv ...Please help
Always smile in the troubled times , there will be never scarcity of smile and happiness in life , one life with many smiles ,a self made heaven
ssdivisiongermany1933 is offline
Old 19-11-2007, 03:16 PM   #2 (permalink)
Rubik's Uncle!!
Charan's Avatar
Default Re: Better Quality on Tv tuner card on cable
first check by relocating your PC at the different points.. if the quality is good at those two points then you may need to change the cable on your PC point..
Charan is offline
Old 19-11-2007, 03:22 PM   #3 (permalink)
relocating is not possible ......
Old 19-11-2007, 04:21 PM   #4 (permalink)
No longer here..
Dude one thing you have to understand .... the TV will always look better and the computer monitor worse as compared.This is because your TV has a lot lower resolution/clarity as compared to the pc monitor.But thats the actual advantage of TV ..... even if the signal is low quality the TV will display it with lower resolution and all the noise and other jitter will be lost and you will perceive a clearer picture.But with a high resolution pc monitor all the noise and grains of the signal are kept intact and thus you actually get to see the real video which is quite noisy and "seems" to be of low quality.
I hope I am not confusing you..!
If you want to try ...then do change the cables or move your pc to the TV's (temporarily) and see if there is any gain in quality.
Also use the same type of video cable that the cablewala uses and not any ordinary wire.Video cables need to be shielded otherwise they are prone to induce noise in them.
indian_samosa is offline
How Improve quality of Cable TV !!! sainit QnA (read only) 6 03-04-2007 02:08 PM
TV TUNER BETTER RECEPTION: COAXIAL CABLE vs PARALLEL WIRE kool Hardware Q&A 7 08-10-2006 05:31 PM
(Cable+Current)->TV Tuner = ????? cvvikram QnA (read only) 1 18-08-2005 11:48 AM
Query Reg Graphics card/TV Tuner card tiwariG QnA (read only) 10 10-09-2004 06:38 PM
- by kool
