Old 18-11-2007, 01:58 AM   #1 (permalink)
Default Run Command
In my PIV old system , afetr I press 'start' button, in the menu the following commands are not found:
RUN,TASKBAR.
How can I retrive them back?. I am daily scanning the system with AVG anti virus free edition. In the controll panel the 'folder option" is not found, due to the lack of these, I cound not control the ystem. Pl help me in fixing the problem.O
pvsraao is offline
Old 21-11-2007, 05:19 PM   #2 (permalink)
Default Re: Run Command
Right click on start button, click on properties. Under taskbar tab click on checkbox next to keep the task bar on top of other windows.
Click on StartMenu tab, then on customize button, then on advanced tab and check the box next to Run command in start menu items to get back the run button
ThinkFree is offline
Old 22-11-2007, 12:11 AM   #3 (permalink)
pushkaraj's Avatar
Once you have got back the run button, just type regedit in it and press enter.
Now go to the following key in
the regsitry:
[Hkey_Current_User\Softwar
e\Microsoft\Windows\Curre
Ntversion\Policies \Explorer]
Go to the right hand side and
create a new reg_dword and
give it a name
"nofolderoptions" without the
double quotes(if the key is already present, just change its value to 0). Then give it a
value 0. Now close the
registry editor. You might have to reboot the
system for the change to take effect.
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
pushkaraj is offline
command in Red Hat ? speedster Open Source 6 04-06-2007 01:52 PM
COMMAND & CONQUER UPDATE - EA shoots out Command & Conquer 3 demo techtronic Gamerz 1 28-02-2007 12:18 PM
command line mp3 vignesh Open Source 6 12-09-2005 07:05 PM
command promt agm_105 QnA (read only) 3 03-02-2005 10:37 AM
- by kool
