Old 15-11-2007, 07:28 PM   #1 (permalink)
bigdaddy486
Posts: n/a
Default Can't change into DMA Mode
I have a LG DVD-RW DL writer and i am not able to change it into DMA mode with Nero DMA Manager. It takes about 51mins to write one full dvd. in the primary channels, i have changed all into DMA, if avalable but in one, it says PIO Mode even i changed it into DMA, if avalable. What should i do? It is also very slow on reading UDF Formatted DVDs and takes about an hour to copy one dvd.......
Also, i have a Sony CD-RW writer and in Nero DMA Manager, it says as it is master and dvd writer is slave. I want the vice-versa, that is, i want sony drive to be slave and lg drive to be master. What should i do?
I want an answer as soon as possible..........
Old 15-11-2007, 07:41 PM   #2 (permalink)
left this forum longback
praka123's Avatar
Post Re: Can't change into DMA Mode
try resetdma.vbs in windows.
http://svp.co.uk/helpdesk/index.php?...nloaditemid=15
praka123 is offline
Old 16-11-2007, 04:24 PM   #3 (permalink)
bigdaddy486
Posts: n/a
Default Re: Can't change into DMA Mode
Thanks.........
It worked...........
N80 & N73 - Change to landscape mode ! arunks Mobiles and Tablets 6 18-04-2008 12:04 AM
change pio transfer mode to UDMA utsav Tutorials 22 06-01-2008 12:24 PM
Difference Between FF Ordinary Mode & FF Safe Mode rajas700 QnA (read only) 9 27-08-2005 02:38 PM
How to change memory bus mode? Mahesh Babu QnA (read only) 1 06-08-2005 04:42 PM
- by kool
