Old 14-11-2007, 03:57 PM   #1 (permalink)
smile's Avatar
Default System Hanging
Hello......guys
My System Is Hanging Always ....i Had Formatted The System...even Ran Antivirus But No Use...still Its Hanging
Intel P4 2.0ghz,
256 Mb Ram,
40 Gb Hdd,
845 Gigabyte Motherboard
SR
smile is offline
Old 14-11-2007, 04:20 PM   #2 (permalink)
Default Re: System Hanging
1. Have you tempered with the BIOS Setts?
2. Are the Drivers Updated?
3. Scan HDD for bad sectors.
4. If you have added any new peripheral check if the SMPS is providing enough power to juice it.
5. What error it gives while hang or just Hangs in the middle of no where?
6. Does it hang running a specific application? or startup / shutdown or randomly?
Phenom II 955 BE @ 4.12 Ghz | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Seagate : 1 TB | NZXT Phantom 410
Elite 335 Cabinet @ 0.8K http://www.thinkdigit.com/forum/baza...ite-335-a.html
Tech_Wiz is offline
my pc is hanging iMav QnA (read only) 13 30-01-2007 06:32 PM
Max payne hanging on Win Xp.. cool_avik Gamerz 4 11-12-2006 07:19 PM
Hanging UPS Kalyan Hardware Q&A 2 05-11-2005 12:59 AM
Hanging ra_sriniketan QnA (read only) 2 23-10-2005 07:46 PM
- by kool
