Old 13-11-2007, 09:41 PM   #1 (permalink)
Default Motherboard upgrade
I have a asrock 775 dual 915gl motherboard. I want to upgrade my motherboard so i can get a new pcie card and upgrade the ram to ddr2. As i will buy the graphics card after sometime as i am into gaming so please suggest me the motherboard according to the gaming requirement. Please tell the best value for money board, As i am somewhat tight on budget. I don't have some specific budget but i want it to be cheap like 3-5k. My processor is socket LGA775. Its a p4 3.0ghz.
zeest is offline
Old 13-11-2007, 10:06 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Motherboard upgrade
Get the Biostar 7050..
If u r taking the gfx card also now only then get the Biostar p35
Pathik is offline
Old 13-11-2007, 10:35 PM   #3 (permalink)
moshel's Avatar
go for a 965G based motherboard...or 965P or 650i ultra if you plan on buying a graphics card now only...becos 965P and 650i ultra dont have onboard video.
moshel is offline
Old 14-11-2007, 10:21 PM   #4 (permalink)
How much they cost?
And how much is the performance difference between 965P,965G and xfx 650i ultra? And which is better? Biostar 7050 or p35? Thanks in advance
bump
zeest is offline
Old 19-11-2007, 12:39 PM   #5 (permalink)
can anyone tell me please the motherboard and their prices in the 4-5k range?
zeest is offline
Old 19-11-2007, 04:27 PM   #6 (permalink)
High without substance...
chicha's Avatar
there is a nice mobo from ASUS i do not rememner the series but it supports HD too and its for 4K in bangalore.
how much are motherboards with SLI cost?
I am Acrophobic, Entomophobic, Melissophobic. :).
chicha is offline
Old 19-11-2007, 08:48 PM   #7 (permalink)
r2d2's Avatar
Intel DG965RY - Rs. 4990
Intel DG33FB - Rs. 5400 (cant take p4)
http://www.newegg.com/Product/Produc...nd&Order=PRICE
r2d2 is offline
Old 19-11-2007, 10:11 PM   #8 (permalink)
moshel's Avatar
the motherboards that i suggested, 965P,965G and xfx 650i ultra are within 5-6 k range...and really if u cant buy a p35/G33/680i mobo, then these are decent offerings.
dude these are the minimum i suggest. vendors will surely tell u to go for 946 boards which is below 4k..but dont buy it..
remember 965P and 650i ultra dont have onboard video.
965G has onboard video.
moshel is offline
Old 20-11-2007, 02:06 PM   #9 (permalink)
Ok. XFX 650i ultra. Does it support LGA 775 i.i can it take p4? And will it give good gaming performance?
I am looking to build this pc.
p4 3.0 ghz HT
2 GB DDR2 667 Mhz RAM
80 GB Seagate Barracuda HD
XFX 650i ultra
XFX GeForce 8800GT.
Will this be able to run crysis at max on 1024x768? No AA or some AF?
zeest is offline
Old 20-11-2007, 02:19 PM   #10 (permalink)
Google Bot
Pathik's Avatar
Your proccy ll be the biggest bottleneck in ur system..
Pathik is offline
Old 20-11-2007, 11:16 PM   #11 (permalink)
moshel's Avatar
http://www.xfxforce.com/web/product/...oductId=989811
moshel is offline
Old 20-11-2007, 11:58 PM   #12 (permalink)
Alpha Geek Banned
bikdel's Avatar
well for the time being you may do with your P4 but then as pathiks said it will be giggest bottleneck and within few months youd have to go for a new processor..
but to play crisis at that settings will be okay because CPU does not play really important role in GFX.. though i think that the AI wont be as good because it needs better physics processing which is handled by the CPU.. and crysis AFAIK wont be enjoyable at anything lower than the hardest level...
anyways enjoy... but with that config be prepared for a proccy upgrade soon ...
BTW 650i Ultra won't support new 45 nm range isnt it?...
If 650 i does not support 45 nm quad cores then PLEASE go for Biostar P35 as it will be a great VFM 45 nm mobo solution...
I'm not a GEEk, i still use Windows!
bikdel is offline
Old 21-11-2007, 11:30 PM   #13 (permalink)
moshel's Avatar
hey i wanna ask 1 question..
when i purchased my current mobo, the asus webpage and the manual didnt say that my mobo supports 45nm procccys...but now when i open the website it says that P5N32 E SLi supports 45nm proccys...
does it mean that my mobo will also support 45nm proccys???
@zeest i dont think that the 650i ultra wud be a problem for some time atleast...becos it supports quad core proccy also. although the P35 is the latest chipset with support for DDR3...so its upto u..
moshel is offline
PC upgrade. Which motherboard, processor and RAM to opt for? aryayush Hardware Q&A 5 01-05-2006 10:04 PM
motherboard upgrade help.. gsmsikar CPU / Motherboards 8 06-03-2006 03:47 PM
graphic card upgrade(PCI) or motherboard upgrade? thetopcyborg Graphic cards 5 13-01-2006 02:32 PM
Upgrade only motherboard prasad_den CPU / Motherboards 4 13-10-2005 08:10 PM
Motherboard Upgrade?-Help needed rakesh_1024 CPU / Motherboards 14 18-08-2004 12:10 PM
- by kool
