Old 13-11-2007, 02:36 PM   #1 (permalink)
elenec's Avatar
Default Low end PC
Hi all,
i need a low end pc that help me download stuff from internet & also i can use it as judebox
also i don't need a monitor as i will be operating thro remote desktop
guy please help with this
regards
elenec
elenec is offline
Old 13-11-2007, 02:41 PM   #2 (permalink)
Rubik's Uncle!!
Charan's Avatar
Default Re: Low end PC
Whats your Budget?
do checkout this Basic Guide Purchase a New System thread.
Charan is offline
Old 13-11-2007, 02:45 PM   #3 (permalink)
elenec's Avatar
Originally Posted by Charan
Whats your Budget?
yes i have checked it & my budget is below 10000 or price that is bare min
i need this pc for judebox & internet so that i can download stuff on this when i'm away from home by using remote desktop
elenec is offline
Old 13-11-2007, 03:01 PM   #4 (permalink)
Elevating Humanity
The Conqueror's Avatar
u can get 15" crt monitor and p3 for about 7-8k. mouse + keyboard = about 500rs.get 5.1 creative inspire for just 3k!total amount = 9 k approx
PS. u can get P2 for even less.
Regards,
The Conqueror
The Conqueror is offline
Old 13-11-2007, 03:07 PM   #5 (permalink)
elenec's Avatar
thank bro,will it support win xp or win me?
elenec is offline
Old 13-11-2007, 03:13 PM   #6 (permalink)
Rubik's Uncle!!
Charan's Avatar
AMD ATHLON 64 3200+ - 1815/-
ASUS M2N - MX SE - 2550/-
512 MB DDR2 - 690/-
80GB Segate HDD - 1800 /-
Cabby + SMPS - Rs. 1200/-
kbd+mouse = 500 /-
Lite on DVD RW - 1340 /-
9895/- + 395 ( 4% TAX ) = 10290 /-
you can remove the DVD RW and reduce the cost further.
Charan is offline
Old 13-11-2007, 03:19 PM   #7 (permalink)
r2d2's Avatar
I purchased the following recently
AMD sempron 3400+ (64 bit)
MSI K9MM-V Motherboard (video, 5.1 surround sound and lan onboard)
Combined Price - Rs. 3600
kingston 512 DDR2 RAM Price - Rs. 750
Other parts I reused from old system
I was surprised to find my new sempron twice as fast as my old P4 1.5
r2d2 is offline
Old 13-11-2007, 03:21 PM   #8 (permalink)
Rubik's Uncle!!
Charan's Avatar
^^ thats a good VFM
Charan is offline
Old 14-11-2007, 06:38 PM   #9 (permalink)
Elevating Humanity
that 1 will run me if u want to run xp then :
BOTH !
if it doesnt run xp, increase RAM to 512mb or 1 GB
NOTE : u can get 2nd hand p4.mostly it'll be good as most people upgrade every year
Regards,
The Conqueror
Old 14-11-2007, 06:53 PM   #10 (permalink)
elenec's Avatar
can u quote me price for the same & what will be configuration
elenec is offline
Old 14-11-2007, 11:23 PM   #11 (permalink)
harryneopotter's Avatar
dude ... dnt go for second hand p4. The configs given by Charan and r2d2 are more thn enuff for casual use ...... choose wat suits ur budget ....
harryneopotter is offline
Old 14-11-2007, 11:43 PM   #12 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
yeah buy the athlon based config less power consumption+less heat and better performer
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 15-11-2007, 01:32 AM   #13 (permalink)
Alpha Geek Banned
bikdel's Avatar
Athlon based <<<<< +1 >>>>>
go for Sempron based system... 160 GB will be good for data storage and downloads
cheapest processor in Sempron line-up - 1500
512 MB DDR 2 RAM - 700
any VIA Based AM2 Mobo - 2000
160 GB HDD - 2500
Cabby+SMPS - 1000
KB + Mouse - 500
DVD RW - 1200 (do u need Optical drive?)
I'm not a GEEk, i still use Windows!
bikdel is offline
Old 15-11-2007, 02:43 AM   #14 (permalink)
Alive Again...
satyamy's Avatar
Where is the Monitor ???
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 15-11-2007, 10:47 AM   #15 (permalink)
elenec's Avatar
160 GB HDD - 2500
Cabby+SMPS - 1000
KB + Mouse - 500
yes i need a optical drive for burn dvd so that in future my HDD doen't get exhausted, also can u give name of via motherbroad which will be perfect for this job
thanks
see this in 1st post
elenec is offline
Old 18-11-2007, 07:42 PM   #16 (permalink)
r2d2's Avatar
@elenec
MSI K9MM-V is a via based motherboard
http://www.msicomputer.com/product/p...9MM-V&class=mb
r2d2 is offline
- by kool
