Old 13-11-2007, 12:49 PM   #1 (permalink)
666
solomon_paulraj's Avatar
Default Two Sound Cards - Possible! Help!
i have onboard 5.1 channel audio and all are connected to 5.1 speakers. now i need to install a tv tuner card which needs a AUDIO-IN socket. so im planning to get a new sound card. because my mobo (Intel 945GCL) does not have any aux input.
my question is can i use the onboard 5.1 for my gaming and dvd and the additional soundcard for watching tv WITHOUT CHANGING THE AUDIO PROPERTIES IN CONTROL PANEL each and every time.
i.e. i want 5.1 as the default for windows sounds, gaming, dvd etc.. and the soundcard as the default for tv tuner card (Leadtek winfast).
MSI-P35-NEO| C2D-E7300 | XV-9600GT | WD-640 | LEADTEK-DTV-1800H | CORSAIR-TWIN2X2048-6400C4DHX | ZEBRONICS-PRO M500W | SONY-DRU-V200S | LOGITECH-X90 CORDLESS
solomon_paulraj is offline
Old 13-11-2007, 07:39 PM   #2 (permalink)
www.VideoEditingIndia.com
VideoEditingIndia's Avatar
Default Re: Two Sound Cards - Possible! Help!
Yes, you can use your new sound card only for watching TV, if your TV Tuner Software supports that facility. If not, you can try Chris TV which allows you to choose the sound card.
And why you need another sound card? Are you using the Composite In instead of Co-ox? Won't your TV card has an audio renderer?
TATASafariClub.com - Its only for MEN - News, Tips, Photos & Guidelines for Men!
VideoEditingIndia.com - Film, Audio, Video Editing & Compositing - Get movie Night Right!
VideoEditingIndia is offline
Sound Problem with Nvdia onboard Sound (hda-intel) Maverick340 Open Source 4 18-09-2007 11:12 PM
Hissing Sound/Disturbance Coming From Speakers/Sound Card ! mikeon Audio 8 15-10-2006 10:37 AM
Suggestions for sound cards please!! baccilus QnA (read only) 8 16-04-2006 11:35 PM
Any experience with buying sound cards? suggest please ! rohanbee QnA (read only) 16 12-05-2005 11:31 AM
- by kool
