Old 12-11-2007, 05:47 PM   #1 (permalink)
smile's Avatar
Default Drives Are Not Opening
HELLO GUYS
I have a strange problem..... whenever i click on d: & f: they are not opening ...am getting the error as "windows cant find copy.exe".But my other drives c: & e: are opening....Can anyone suggest what is the problem ..Is it a Virus
smile is offline
Old 12-11-2007, 06:01 PM   #2 (permalink)
Default Re: Drives Are Not Opening
Originally Posted by smile
HELLO GUYS
First end the task called temp1.exe by opening the task manager with ctrl+alt+del key and then remove the files copy.exe, host.exe and then autorun.inf from the all the drives. If the file is hidden, then enable 'show all files' and then delete it.
Hope it may solve.
goldy_connect is offline
Old 12-11-2007, 06:03 PM   #3 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
[Windows] FreQuently AsKed ProBlems WITH SoluTions...
Buddy...........
Pls ....Pls ......Pls
Search Before You Post
||uLtiMaTE WinNER||
Ron is offline
Old 12-11-2007, 06:23 PM   #4 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
^^ Thanks buddy.
Just read Point. 3 in the FAQ thread:
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Drives Are Not Opening smile Software Q&A 2 11-11-2007 11:26 PM
Drives Are Not Opening smile Software Q&A 3 09-11-2007 10:07 PM
Drives Not Opening... Help Required.... RoughGuy QnA (read only) 6 25-03-2007 10:37 PM
drives not opening sharma_atul85 QnA (read only) 4 25-03-2007 10:35 PM
drives not opening Naveed Software Q&A 1 15-03-2007 08:51 PM
- by kool
