Old 11-11-2007, 05:32 PM   #1 (permalink)
g_goyal2000's Avatar
Default Computer off, power light blinking
For my system configuration, see my signature.
I have a dekstop, not a laptop.
Yesterday, I experienced a strange problem.
My computer had been up for about 2 hours.
The internet was on and Bitlord was running along with anti-virus & firewall.
I left the computer running and took a break. I had turned off the monitor.
After about 10 minutes, I noticed the computer had shut down.
But it's power light was blinking with an interval of about 2-3 seconds.
Everything else connected to computer was off.
Even the SMPS was off & it's fan wasn't running.
When I pressed the reset and power buttons, nothing happened.
I tried moving the mouse and pressing keyboard keys but nothing happened.
I eventually had to turn off the UPS to shut down everything.
The Windows Event Viewer shows nothing related to this problem.
I have checked the power settings & everything is fine.
This problem has occurred for the first time.
What could have happened?
Come on guys...
Is there no one who could have possible explanation?????
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
g_goyal2000 is offline
Old 11-11-2007, 05:43 PM   #2 (permalink)
Dreamweaver
Gigacore's Avatar
Default Re: Computer off, power light blinking
What a strange prob.. which is ur MOBO... give some detailed specs ..
Gigacore is offline
Old 11-11-2007, 07:25 PM   #3 (permalink)
Still in war with allies
ssdivisiongermany1933's Avatar
it happened to me once , but came back after some thoka- piti .... just a hit and trial method
Always smile in the troubled times , there will be never scarcity of smile and happiness in life , one life with many smiles ,a self made heaven
ssdivisiongermany1933 is offline
Old 11-11-2007, 07:32 PM   #4 (permalink)
Wire muncher!
infra_red_dude's Avatar
Looks like your computer has gone to Sleep or Standby mode (S3 or so state) and is unable to wake up. Try disabling Standby and see if it solves the problem. This may also be due to graphic drivers. Try updating them.
infra_red_dude is offline
Old 12-11-2007, 11:41 AM   #5 (permalink)
No, I don't use the standby mode (affects HDD) & keep it disabled. But even if it had gone into standby mode (which it didn't), the system power light shouldn't have been blinking.
I am using the latest graphics driver.
Since the problem has happenned for the very first time, I won't do it. But if it again occurs, I might consider it.
My motherboard is MSI K8N Neo2-FX.
http://asia.msi.com.tw/index.php?fun...4&maincat_no=1
Old 12-11-2007, 12:18 PM   #6 (permalink)
Wire muncher!
At least in my laptop the LEDs blink when in standby mode. Just ensuring that Standby in Windows is disabled won't do. Check your BIOS for Power Management settings.
Old 13-11-2007, 04:14 PM   #7 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
this might b standby or hibernating ........ check it out .........
... W H O T ...
ax3 is offline
Old 17-11-2007, 12:18 AM   #8 (permalink)
Unhappy Re: Computer off, power light blinking
Well, the problem happened again tonight.
But this time, it occurred while I was working.
The computer, just, turned off as if someone cut-off the power to computer.
And the power light started blinking.
Well, it's a desktop, not a laptop. I have set no specific setting regarding power management, neither in Windows nor in BIOS.
I keep standby setting disabled. But I still checked & it was disabled.
As for going in hibernation, it can't be possible & is not that.
I have put my PC in hibernation many times previously.
In case of hibernation, Windows saves the environment & shows the progress after which the computer turns off, along with power light.
But in my case, the computer just turns off without any warning or prompt or error even while I'm working. And the always on power light starts blinking.
Plz, Plz, Plz..... Help me!!!!
Old 17-11-2007, 12:26 AM   #9 (permalink)
TheSaint
NucleusKore's Avatar
Doesn't look good. I had this problem two months back. Would return to find my pc in the same state as you mentioned. Had problems with the SMPS, got it fixed. Then SMPS got spoilt again, bought a new power supply unit. Finally ended upgrading processor, motherboard, RAM, hard disk
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 17-11-2007, 12:42 AM   #10 (permalink)
Wire muncher!
Yeah check the SMPS. Also check the power connector of the HDD.
Old 17-11-2007, 12:56 AM   #11 (permalink)
TechTin.com
ravi_9793's Avatar
may be some voltage fluctuation..and system turned off.
ravi_9793 is offline
Old 17-11-2007, 09:59 AM   #12 (permalink)
So you're saying that the root of the problem was SMPS?
But then why did u end up upgrading u'r processor, motherboard, RAM, hard disk? Did the faulty SMPS damage your hardware?
I use APC UPS which has inbuilt AVR.
I'm having another problem. Could it be related to this problem?
Hard Disk Light problem
Old 17-11-2007, 10:10 AM   #13 (permalink)
TechTin.com
ravi_9793's Avatar
How can we exactly say about the problem.you were not present with your system..may be any kid in your family has done something.
You continue computing your system, if in between your work it shut down, than there is some problem.
Overheating is also a cause of unwanted shutdown.
Old 17-11-2007, 07:17 PM   #14 (permalink)
How can we exactly say about the problem. you were not present with your system..may be any kid in your family has done something.
What r u, blind????
I guess u didn't read my previous posts. In my third post, I have clearly mentioned that the second time, the system turned off while I was working on it.
BTW, there is no kid in my family & no one except me in my home is awake at night at 12 am.
Old 17-11-2007, 07:21 PM   #15 (permalink)
TechTin.com
ravi_9793's Avatar
If system turn off suddenly without any reason, than over heating may be a cause.If possible add a extra fan to your cabinet.
Check SMPS , processor, cabinet fan.Also clean cabinet and processor fan.
Also see my last post in this thread
pc restarting without any reason
Old 18-11-2007, 11:59 AM   #16 (permalink)
If system turn off suddenly without any reason, than over heating may be a cause. If possible add a extra fan to your cabinet.
Well, I keep one side of the cabinet open. And BTW, it's cold here (Winter's almost "officially" here). So, overheating can't be a problem.
If only I can find out why the power light constantly blinks indefinitely after sudden "shutdown", maybe that'll help me determine the problem.
I can clean processor fan but not SMPS fan.
Old 19-11-2007, 08:45 PM   #17 (permalink)
Ok, I've just changed the IDE cable.
Apparently, it was causing another problem which got solved when I replaced it.
I hope this problem too was due to the faulty IDE cable & gets solved after this.
Old 19-11-2007, 11:59 PM   #18 (permalink)
TechTin.com
ravi_9793's Avatar
congrats for having a healthy system
Old 21-11-2007, 11:01 AM   #19 (permalink)
I never said my system was healthy again.
For starters, since past year, my hard disk has been making a click noise everytime I start my PC. It never happenned before that.
Secondly, something from my PC is making a large vibrating sound which gradually dies out.
Thirdly, my new optical mouse's pointer is jumping.
Last, but not least, is my combo drive which is able to read all readymade/pre-written DVD's (read software, movie, magazine DVD's) but not the DVD's burned by me or my friends.
Do u still say that my PC is healthy??
Old 21-11-2007, 11:10 AM   #20 (permalink)
NP : Crysis
xbonez's Avatar
Maverick340 of this forum, a friend of mine, was facing the same problem about a week ago. he got his drive replaced since it was in guarantee period. is ur drive in guarantee period? if yes, get a replacement
xbonez is offline
Old 21-11-2007, 11:24 AM   #21 (permalink)
No, it's not in warranty period. Well, it sometimes read my custom burned DVD's (read 1-2 times out of 10 times).
But I also have a DVD writer, not much problem except that I can't make direct copies of DVD's. I have to copy an image on my HDD & then burn it.
Old 21-11-2007, 12:20 PM   #22 (permalink)
"The Gentleman"
vish786's Avatar
check ur laptop manual for different blinking status/troubleshooting indications... AFAIK its blinks when in standby mode.
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 21-11-2007, 12:54 PM   #23 (permalink)
NP : Crysis
xbonez's Avatar
yes, the power light is supposed to blink when in stnd by mode. but his prob was obviously not that since the comp is supposed to wake up when u press the power button...
xbonez is offline
Old 21-11-2007, 03:53 PM   #24 (permalink)
I think u didn't read all my posts. I have a desktop, not a laptop.
Correct.
Old 12-12-2007, 06:46 PM   #25 (permalink)
Ok, today it happened again.
Any suggestion, solutions please.
Old 13-12-2007, 10:42 AM   #26 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
Why don't you try replacing the SMPS? This might be at fault. For your hard disk, time to get a new one. Your HD is taking it's last breath. It might crash anytime and your data might not be recoverable. So, take care!
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
Old 14-12-2007, 11:11 PM   #27 (permalink)
Ok, I'll get my SMPS checked.
As for my HDD, the problem was with IDE cable which turned out to be faulty.
I replaced it & all the HDD issues are gone.
Old 25-05-2008, 08:33 PM   #28 (permalink)
Pretty late to post a reply but will still do.
The problem was with SMPS.
It's fan, capacitor & a few PCB's had gone nuts.
Got the SMPS repaired, problem gone.
Thanks everybody for u'r help.
when i am starting my PC cabinet-light starts blinking 56561 Hardware Q&A 4 26-04-2007 10:41 AM
Blinking Power Led keep_it_rl Hardware Q&A 8 07-04-2007 08:04 PM
Hdd light blinking ! ! ! ax3 QnA (read only) 6 18-05-2006 11:34 AM
Light power point files! abhijitroy Software Q&A 6 28-10-2005 04:40 PM
Monitor and Monitor Power Light is blinking aathif QnA (read only) 4 21-05-2005 05:20 PM
- by kool
