Old 10-11-2007, 12:34 PM   #1 (permalink)
Default Query about SATA power cables
I recently purchased a new budget computer. I only purchased the new CPU and motherboard with new tower including power supply. Other things I am using are from my old computer. New computer has AMD X2 5200+ CPU and M2A-VM motherboard which has 4 SATA and 1 PATA connectors. But the power supply (Circle brand) has only 1 SATA power cable. Others are all PATA power cables. I asked the dealer why this is the case then he said I need to buy a SATA power cable extension. Is what he said is true? Why only one SATA power cable? I already have a old computer with 160 GB HDD and a LG DVD writer which are under warranty. So I want to use them now with new computer as I am not going to sell my old computer and use it for experimentation purpose. Is it advisable to use HDD and DVD writer as master and slave on single PATA connector for my new computer?? Should I purchase at least one of the SATA version?
Anyone who has never made a mistake has never tried anything new
sandeepk is offline
Old 12-11-2007, 11:38 AM   #2 (permalink)
Default Re: Query about SATA power cables
There is nobody who knows about this? I am very much unfamiliar with SATA. So please guide me for this.
sandeepk is offline
Old 12-11-2007, 12:20 PM   #3 (permalink)
Rubik's Uncle!!
Charan's Avatar
Yea you have to buy a SATA power cable.. only high end SMPS comes with fixed SATA power pins.. Each cable will cost you about 25 bucks.
Charan is offline
Old 12-11-2007, 12:21 PM   #4 (permalink)
Dreamweaver
Gigacore's Avatar
^ The local one costs 20 Rs... but dont go for it! ..... my friend bought one and it burnt!
Gigacore is offline
Old 12-11-2007, 12:34 PM   #5 (permalink)
Wire muncher!
infra_red_dude's Avatar
IMHO there was no need to change the power interface on SATA disks. I dunno what led the manufacturers do it. Hafing all those "adaptors" looks ugly in the cabinet!
Get the power connectors for about Rs.30. Good quality ones can be identified by feeling the connectors. They feel strong and rigid.
infra_red_dude is offline
Old 12-11-2007, 12:39 PM   #6 (permalink)
Rubik's Uncle!!
Charan's Avatar
^^^ Actually I think its for hot swapping the drives.. AFAIK SATA drives supports hot swapping
conventional power connectors wont enable hotswapping
Charan is offline
Old 12-11-2007, 04:39 PM   #7 (permalink)
Nav11aug's Avatar
and all the cribbing about the traditional power cables. They really sucked. For one, it woudn't detach from the drive
http://www.last.fm/user/NOLFxceptMe/
http://naveendageek.blogspot.com
Back after a long time. And well, EndSems screwed up as usual :)
Nav11aug is offline
Old 12-11-2007, 06:10 PM   #8 (permalink)
Where I need to attach them? To the existing PATA connector? Or directly to SMPS? My dealer will help me with this but still better to know from you guys..
sandeepk is offline
Old 12-11-2007, 06:45 PM   #9 (permalink)
Rubik's Uncle!!
Charan's Avatar
look at this picture and I guess you will understand it
Charan is offline
Old 12-11-2007, 08:08 PM   #10 (permalink)
@charan
thanks.
sandeepk is offline
Old 13-11-2007, 01:03 AM   #11 (permalink)
for that u hav e-SATA port.
Faun is online now
Old 13-11-2007, 09:49 AM   #12 (permalink)
^^ What do you mean by that?
sandeepk is offline
Old 13-11-2007, 10:33 AM   #13 (permalink)
better go through this article
http://en.wikipedia.org/wiki/Serial_ATA
Faun is online now
Old 13-11-2007, 04:26 PM   #14 (permalink)
Nav11aug's Avatar
Nav11aug is offline
Old 13-11-2007, 04:38 PM   #15 (permalink)
@T159
I now know the details about SATA. But eSATA does not provide power similar to USB. So what does your comment means?
sandeepk is offline
Sata power adaptor burnt.. dip_10 Hardware Q&A 15 08-10-2007 04:30 AM
Data Cables [A]bu Hardware Q&A 1 20-05-2007 10:46 PM
PowerSafe 400 Watts SMPS vs. VIP 450-Watts SATA Power Supply shyamthakkar QnA (read only) 2 28-10-2004 07:35 PM
- by kool
