Old 10-11-2007, 11:44 AM   #1 (permalink)
Default USB to USB data tranfer Vista
I bought a USB to USB data transfer cable, I got a cd with it which installed pc-linq, but i can't seem to get it work with my laptop which has windows vista. Is there some special cable needed for vista-xp transfer, or am i just in need for some drivers?
Is the pc linq driver sufficent?
thanks
chillnow is offline
Old 12-11-2007, 08:35 PM   #2 (permalink)
Default Re: USB to USB data tranfer Vista
Buzz
chillnow is offline
Old 12-11-2007, 08:47 PM   #3 (permalink)
Rubik's Uncle!!
Charan's Avatar
Check if you have the correct drivers installed for both vista and xp.
Sometimes this just happens. I haven't really found out why. But for the convenience of PC Linq when it works, it's worth sticking with it.
Try any or all of the following:
1. Make sure you have the latest version of PC-Linq running on both PCs. Click Help > About and it should say Version 1.64. If not, get the latest version via the link above.
2. Shutdown PC-Linq on both computers (if you have a task manager, use this to check that the application is truly shut down), unplug the cable, wait 10 seconds, plug the cable in again (using different USB sockets if available), Restart PC Linq.
3. As above, but shut down the PCs as well before restarting everything
4. Uninstall and reinstall PC-Linq on both computers.
Link
if you have a Ethernet port in you PC and as well as in your lappy then just use a crosscrimped(corssover) cable and setup network. This wil be more simple.
Charan is offline
Old 12-11-2007, 09:02 PM   #4 (permalink)
Google Bot
Pathik's Avatar
^^ actually the usb 2 usb cable is used if u just want PnP.. No settings needed unlike a crossed rj45..
Pathik is offline
Old 12-11-2007, 09:05 PM   #5 (permalink)
Rubik's Uncle!!
Charan's Avatar
no need of drivers or custom softwares?
Charan is offline
Old 14-11-2007, 11:16 AM   #6 (permalink)
I checked. pclinq is ver 1.64. and i have tried reinstalling everything and restarting. what correct drivers do i need for xp or vista?
i wonder if there is a compatibility issue with vista and pc linq or the cable.
thnks
chillnow is offline
How to tranfer money from credit card to paypal? valpuia Chit-Chat 1 17-10-2007 03:22 PM
usb data cable for vista Amir.php Hardware Q&A 1 03-10-2007 05:43 PM
wanna wite data and mp3 in win vista. mohitgiri Software Q&A 7 23-04-2007 07:29 PM
how to tranfer bookmarks frm Opera to Firefox Manshahia Software Q&A 2 08-03-2007 11:15 AM
Any one knows how to tranfer DATA from PC to Laptop thru USB Yoda Peripherals 6 15-12-2004 04:05 PM
- by kool
