Old 10-11-2007, 09:31 AM   #1 (permalink)
moshel's Avatar
Default Problem somewhere in the comp
hi guys..
i have an odd problem in my comp...my config is written in my sig....
now the computer starts ok and all....but games are not working....i get either BSOD or the comp restarts or the game crashes.....in short graphics heavy things are not working
it started when yesterday the AVG antivirus updated itself and i restarted my comp...since then this is the problem...i uninstalled AVG..but still the same prob
i opened the case took out the ram and put it in again....cant do same with my graphics card as im not aware of the system for removing it...in this case i mean (i used to remove the graphics card in my old comp by myself)
pls help guys...thx..
moshel is offline
Old 10-11-2007, 09:51 AM   #2 (permalink)
assasin's Avatar
Default Re: Problem somewhere in the comp
^^^ restore ur system using System Restore to a time when ur pc was working perfectly.
assasin is offline
Old 10-11-2007, 02:14 PM   #3 (permalink)
moshel's Avatar
ok so i did system restore...then i started my comp and after a few mins i got BSOD saying "IRQL_NOT_LESS_OR_EQUAL"
moshel is offline
Old 10-11-2007, 02:55 PM   #4 (permalink)
Proud to be Linux
abhinandh's Avatar
This error usually occurs after the installation of a buggy device driver, system service, or BIOS.
what version of avg did you install?
http://abhinandh.com
abhinandh is offline
Old 10-11-2007, 05:31 PM   #5 (permalink)
moshel's Avatar
i already had AVG.....its just that the program updated itself when i switched on my comp and then it asked me to restart the comp and then the problem started.....the update happens everytime i start the comp but thats mostly the virus definitions...
i suppose the version was 7.5.
moshel is offline
Old 11-11-2007, 08:09 AM   #6 (permalink)
Proud to be Linux
abhinandh's Avatar
Question Re: Problem somewhere in the comp
hey use ccleaner to clean the registry and temporary files and try..
does this happen even in safe mode???
Problem With Comp-video Out... gannu_rox Hardware Q&A 6 05-07-2007 10:39 PM
H'to conekt Off Comp with Home Comp abhijitroy QnA (read only) 2 22-01-2007 10:53 PM
New cd rom in old comp vasanth_12345 QnA (read only) 14 02-06-2005 05:29 PM
Strange comp problem.. krisjr QnA (read only) 8 10-03-2005 12:45 PM
- by kool
