Old 07-11-2007, 11:37 PM   #1 (permalink)
Arun the Gr8's Avatar
Default help in connectin' lan
hi,
i hav a prob in connectin 2 pcs in lan. i hav a cross-cable n i hav did it b4 but i dont know,
now a days they never connect. firstly, it shows limited or no connectivity n secondly only my
own pc is displayed in my network neighbourhood. both d comps hav win xp pro n i use d wizard
2 connect them... HELP!
New Dell Inspiron 14: Intel Core i3 350 - 2.26 GHz, 2 GB DDR3 1066 MHz RAM, 320 GB 7200 RPM HDD, 512 MB ATI Mobility Radeon HD 4330
Arun the Gr8 is offline
Old 07-11-2007, 11:44 PM   #2 (permalink)
"The Gentleman"
vish786's Avatar
Default Re: help in connectin' lan
recheck /redo settings
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
help for LAN connectin nevillle23 Networking 1 03-07-2005 01:25 AM
problems connectin 6600 usin bluetooth bizzare_blue QnA (read only) 2 05-05-2005 08:02 PM
- by kool
