Old 07-11-2007, 09:45 PM   #1 (permalink)
G.A.M.E.R
Shloeb's Avatar
Default Pc upgrade
My friend wants to upgrade his motherboard, processor and ram. He currently has a p3, 865 mobo and 256 mb ram.
His budget for the motherboard+processor and ram is 10,000. He will use the pc for some gaming and multimedia stuff. Please don't suggest a graphics card. He won't buy it.
One more question is that. Should he go for amd or intel? Which will perform better at this budget? Thanks.
Core2Duo E7200 @ 3.16 Ghz| ABIT IP35-E | 2GB Transcend 800Mhz | GeCube ATI HD 4850 | 250 GB Western Digital | Corsair VX450W
Dell Studio 1558
Shloeb is offline
Old 07-11-2007, 09:55 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Pc upgrade
AMD obviously..
MSI K9AGM2
AMD x2 5600+
2*1GB DDR2 667mhz ram
Pathik is offline
Old 08-11-2007, 02:53 PM   #3 (permalink)
G.A.M.E.R
Shloeb's Avatar
Any other suggestions? Isn't 1GB RAM enough? And please post the prices of the components.
Dell Studio 1558
Shloeb is offline
Old 09-11-2007, 05:06 AM   #4 (permalink)
help! im gonna upgrade my computer in a few weeks and my budget's like 27000 to 30000...i have to buy a new mobo, processor, 1gb ram, smps, 250GB hdd, graphic card(dx10) and a dvdwriter..what do you guys suggest coz my budget's a lil limited...ill be using the pc primarily for movies, songs and to play games...im willing to sacrificing quality for the games and I'll be happy as long as i can play new games on it...im willing to turn off most of the eye candys as long as its playable...my order of priority goes something like this...mobo, processor and power supply comes first....then its the HDD, graphic card, RAM...if i have a little left over then i wouldn't mind a new cabinet and dvd writer as well...my next upgrade will be like the end of next year so i have to be v careful of what i choose...what do you guys suggest???i have come up with a list of what i plan to buy below...please help me with your suggestions...
1. CPU-> AMD Athlon 5200+x2; Price:Rs.5,625
2. Mobo->Asus M2NPV-VM; Price:Rs.4,275
3. RAM- DDR2 800 Mhz 1GB; Price:Rs.4,000
4. HDD->Western Digital Caviar SE16 WD3200AAKS 320GB; Price:Rs.3,800
5. Cabinet->Zebronics peace; Price:Rs.2,300
6. LiteOn DVD writer; Price:Rs.1350
7. Coolermaster extreme power 600W;Rs. 3500/
8. GPU(DX10)???????????? Price:Rs.5150
TOTAL=Rs.30,000
if i spend 30,000 it means that 7,000 comes from my pocket...where can i cut a little cost...help!
p.s. posted this at skoar.com also
samus_guild is offline
Old 09-11-2007, 06:57 AM   #5 (permalink)
Gizmo Freak !
spitfire's Avatar
TOTAL=Rs.30,000
Welcome to the forum.
But first of all you should hav looked at and searched the forum first..as the forum is flooded with the same kind of posts.
Secondly You shouls not hijack others thread like these..posting in forum is free so open your own thread to ask questions..
Thirdly your RAM price is extorbitantly high..4000 for 1gb 800Mhz is way too high (Unless you opt for performance rams).
as far as DX 10 cards go..8600gt seems only viable option
spitfire is offline
Old 09-11-2007, 03:53 PM   #6 (permalink)
sorry about this and thanks for the reply...will search the forums and will not hijack other threads....and thanks for the info on the RAM prices and graphic card...thats another 1000 bucks saved...
Old 09-11-2007, 04:11 PM   #7 (permalink)
G.A.M.E.R
Shloeb's Avatar
Can somebody answer me?
Dell Studio 1558
Shloeb is offline
Old 09-11-2007, 07:54 PM   #8 (permalink)
tech mighty
arun_chennai's Avatar
Intel Core 2 duo E4500 2.2Ghz =4.8k
Biostar 7050 =3.2k
2Gig Transcend =2kk
Total =10k
Overclock this baby to 3ghz and it will any AMD offering....
1gb is not enough.....
Last edited by arun_chennai; 09-11-2007 at 07:54 PM. Reason: Automerged Doublepost
arun_chennai is offline
Old 09-11-2007, 10:31 PM   #9 (permalink)
Google Bot
Pathik's Avatar
^^ i think u mean the Biostar 7150..
http://www.biostar-usa.com/mbdetails...del=TF7150U-M7
Pathik is offline
Old 09-11-2007, 10:50 PM   #10 (permalink)
tech mighty
Actually the model u have suggested is better than what i have suggested (with DVI & HDMI & Better Graphics) ,but it is not yet available in India .the model i have suggested is http://www.biostar.com.tw/app/en-us/...t.php?S_ID=307.the only downside of these motherboards are lack of dual channel ram...but for 3.2k they offering Penryn support with a very good IGP....
Old 10-11-2007, 11:59 AM   #11 (permalink)
G.A.M.E.R
Shloeb's Avatar
The problem is that Biostar may not be available here. Any other popular brand of motherboard?
Btw which is better? E4500 or 5600+?
Dell Studio 1558
Shloeb is offline
Old 10-11-2007, 05:28 PM   #12 (permalink)
tech mighty
Biostar is distributed by Abacus peripherars & it has branches all over India....
Old 10-11-2007, 09:09 PM   #13 (permalink)
Google Bot
Pathik's Avatar
yea man Biostar makes great vfm mobos.. btw @stock the 5600+ is better than the 4500.. but wen OCed e4500 may win..
Pathik is offline
Old 11-11-2007, 10:36 AM   #14 (permalink)
tech mighty
Thats true....
Old 11-11-2007, 11:17 AM   #15 (permalink)
Alpha Geek Banned
bikdel's Avatar
Biostar 7050 =3.2k
2Gig Transcend =2kk
Total =10k
+1
and as dual channel support isnt available it would be Advisable to invest 800 Mhz ram than a 667 one..
and please dontmiss this sticky now onwards, its dedicated to such queries...
Basic Guide Purchase a New System
I'm not a GEEk, i still use Windows!
bikdel is offline
Upgrade woo-hoos to Upgrade blues. Help! mightyboosh Hardware Q&A 1 27-11-2006 12:14 AM
AMD system upgrade..err??no u all bored of upgrade forums but pls do help me...!! karthik316_1999 Internet & WWW 11 18-07-2006 08:10 PM
graphic card upgrade(PCI) or motherboard upgrade? thetopcyborg Graphic cards 5 13-01-2006 02:32 PM
upgrade pc bass QnA (read only) 8 23-06-2005 11:00 AM
- by kool
