Old 07-11-2007, 09:13 AM   #1 (permalink)
M3TAL H3AD M3
skippednote's Avatar
Lightbulb Final help
I would like to ask you all who r using (ASUS m2a vm). How is the performance of the mobo overall for playing games and for vista. Please name the games you play with this mobo and do they run vista fine. One more thing can I add a NVIDIA graphics card to it.
and pls reply to the pic i had added in my last post
thank in advance
I spit Rainbows.
skippednote is offline
Old 07-11-2007, 09:54 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Final help
Yes... any x16 GRFX Card inder PCI-e Intercfe would work fine with the board....
Yes the onboard ATi x1250 its 3.0 for Ratings under grfx an the chipset is fully vista certified !!
Motherboard can play any game actually its not motherboard which is the part to consider the Game play... its Processors or Grfx card or onboard grfx to cosider the performance of the game...
for this question visit here and go through the last pages... Will this game run on this configuration?
if considering just the mobo performance then yes the chipset and mobo performes great under Vista or any apps... now if u are asking for onboard grfx its more than enough to run Vista under its full glory, but nvidia 6150 would be better than AMD 690G when comes to onbord game play...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 07-11-2007, 10:24 AM   #3 (permalink)
Google Bot
Pathik's Avatar
The only hitch is that it supports only shader model 2.0..
Pathik is offline
Old 07-11-2007, 10:33 AM   #4 (permalink)
M3TAL H3AD M3
wat if i later go for a graphics card then which is te better mobo
I spit Rainbows.
nLite 1.3 Final alsiladka Technology News 9 06-03-2007 10:51 AM
µTorrent 1.6 Final rakeshishere QnA (read only) 10 08-07-2006 11:01 AM
OpenOffice.org 2.0.2 - Final rajat22 Software Q&A 5 03-05-2006 08:54 PM
where to get FC5 final santu_29 Open Source 28 15-04-2006 11:30 AM
Please Help me to Final my Config Monster_AMD QnA (read only) 7 24-05-2005 09:08 AM
- by kool
