Old 06-11-2007, 10:35 PM   #1 (permalink)
rahul_jaiswal31's Avatar
Default portable harddisk or **ck disk
hi guys. this problem will make me die.
i am using a portable harddisk 1st time.
when i connect it via usb, only the light in d hd
glows up. there is no drive letter or anything else that
shows hd is connected. please help me in this situation while
the dealer doesn't know anything
rahul_jaiswal31 is offline
Old 06-11-2007, 10:53 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: portable harddisk or **ck disk
If you are using one un-partioned HDD then even the HDD is powered up, you will not see any drive letter as there is no usable partion in it...
Do one thing, Go to Disk Management....
by Right Clicking to My Computer, then Click Manage...
In the computer management console, please use the left navigation to go to Disk Management
Now in there if you see unallocated space as in Black, then please format that as per you need or if u see active partion but without any drive letter then please asign a drive letter to use it under windows, by right clicking up on them...
thank you...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 06-11-2007, 10:54 PM   #3 (permalink)
manishjha18's Avatar
u have to first format it-right click in my computers-manage-storage-disk management--in xp
manishjha18 is offline
Old 07-11-2007, 11:49 AM   #4 (permalink)
thank you...
i didnot seen any unallocated partition. pls help
Portable Hard Disk Suggestion prasanna7287 QnA (read only) 7 01-11-2007 10:56 PM
portable harddisk problem manishjha18 Hardware Q&A 3 29-09-2007 09:24 AM
portable harddisk problem manishjha18 Hardware Q&A 1 19-08-2007 10:34 PM
Portable hard disk Angad singh Hardware Q&A 4 28-11-2006 09:32 PM
paralal portable harddisk a_dalui QnA (read only) 1 13-08-2005 09:21 PM
- by kool
