hey , Recently Purchased 1 GB dynet DDR 400 ,and set Up them with 2*512 DDR
400 Transcend Ram . Now Iam facing frequent Reboots , PC is not working properly ..
When I insert Single Dynet module PC works ,and same happens when two Transcend Rams too , but Not all three at Ones
I have MSI K8NGM2-L mainboard ,how can I get running all my Ram pls help
Regards
thanks
Always smile in the troubled times , there will be never scarcity of smile and happiness in life , one life with many smiles ,a self made heaven
This is happening due the difference in ram module architectures and or speed.
Many members in this forum have asked about using ram modules from different brands together and this is what happens.Even if the system does boot you might have memory data transfer and usage corruption.
yaah System boot ,is there any way or i have to dump my One of Ram
You can try ram module combination in different slots and if that doesn't help u'll have to dump your ram modules.I suggest you use the two transcend modules in different channels(without the dynet module).This will help you set up dual channel configuration and will double your performance.
