Old 06-11-2007, 10:51 AM   #1 (permalink)
midhunmon's Avatar
Default Hard Drive hangs after a clicking noise
Recently i have aquired a new problem, sometimes while working there is a strange clicking noise in th HDD and the system hangs.Then i have to restart it.sometimes the problem persists untill i reconnect the IDE cable of the HDD.
I have seen this kind of problem in my software institue which makes the system hang and having the need to reconnect the IDE cable.I am not sure whether it has the same clicking noise.When this happens the HDD is not detected in the BIOS and an "Insert Correct Boot Device" mesage appears.
The 12V and 5V are achieved correctly.
But What exactly is causing the problem, 'cause all other times it works like nothing's happened.
midhunmon is offline
Old 06-11-2007, 05:37 PM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Hard Drive hangs after a clicking noise
^^ You need buy a new HDD
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Hard Disk makes noise & whistles g_goyal2000 Hardware Q&A 20 25-05-2008 08:00 PM
Hard Disk makes noise & not detected g_goyal2000 Hardware Q&A 8 25-05-2008 07:44 PM
c drive not opening on double clicking kooabs03 Software Q&A 16 17-11-2007 06:09 PM
Double clicking on drive opens search! DizitalNovice QnA (read only) 6 24-05-2007 12:01 AM
Noise in Hard Disk... shariq_pj Hardware Q&A 12 10-11-2005 09:29 AM
- by kool
