Re: Intel CPU Ucode loading error
I just upgraded my PC with the new processor Intel E7200 2.53 Ghz Core 2 Duo 45nm with motherboard ASUS P5LD2 & am getting this error even after formatting for Win Xp Sp2
The remaining of my configuration has remained same except for the processor; have no clue what to do..some forums said to upgrade bios & check CMOS battery..but what are these other errors, I haven't done any overclocking!>!?!?! Am I supposed to overclock my motherboard, is that recommended or safe?
Also at the moment there is no Windows XP on it as I formatted it earlier & the time it asks you to reboot when done formatting my computer shuts off before installing XP. No issues I turn it on to install XP again towards the end it asks u to reboot and again my comp shuts off. Thereafter I have to pretty much go thru the procedure again....
PLEASE PLEASE HELP!!!
Intel CPU uCode loading error
CPU Over Voltage Error!
Overcl****ing failed or Overvoltage failed! Please enter Setup to re-configure your system
Press F1 to Run SETUP
Press F2 to load default values and continue
My Comp Config:
CPU
Intel Core 2 Duo 2.53 Ghz E7200 45nm
Motherboard
Asus P5LD2
Memory
Corsair 2GB
Graphics Card
Geforce 8600GT
Hard Drive
Seagate SATA 160, Seagate SATA 1TB, Samsung 80GB
Sound Card
Turtle Beach Voyetra
Power Supply
VIP 350w
Case
VIP
OS
Windows XP Pro SP2
Monitor
Dell Ultra Sharp 22" Wide
The previous configuration was only a different processor which was the Intel Core 2 Duo 1.86 ghz, I am unaware of the model number at the moment though but it was a 65nm processor.
Please help, how do I upgrade the BIOS if Windows XP cannot install? Do I need to overclock?
