Old 05-11-2007, 04:21 PM   #1 (permalink)
Phenom II X4 920 Owner
prateek_san's Avatar
Red face Processor temp !
guys my CPu temp is 61 c at idle time had to change my Intel cpu fan it wasnt working at present using a new cpu heatsink....any suggestion on how i can lower these temp values.....pls guys help me
"A strong positive mental attitude will create more miracles than any wonder drug." - Patricia Neal
prateek_san is offline
Old 05-11-2007, 04:30 PM   #2 (permalink)
Default Re: Processor temp !
Only way to lower the CPU Temp is to use good heat sink and also good ventilation in the cabinet. In case you have OCed revert back to default this will also bring down the temp.
Phenom II 955 BE @ 4.12 Ghz | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Seagate : 1 TB | NZXT Phantom 410
Elite 335 Cabinet @ 0.8K http://www.thinkdigit.com/forum/baza...ite-335-a.html
Tech_Wiz is offline
Old 05-11-2007, 04:33 PM   #3 (permalink)
Old 05-11-2007, 04:56 PM   #4 (permalink)
OC = Overclocking of CPU. For this vCore Voltage is sometimes increased resulting in more heat.
Tech_Wiz is offline
Old 05-11-2007, 04:57 PM   #5 (permalink)
-----ATi-----
nvidia's Avatar
Dont OC your CPU and run it under stock speeds and add 1 or 2 extra fans in the Cabinet..
http://twitter.com/akshayms
nvidia is offline
Old 05-11-2007, 05:38 PM   #6 (permalink)
guys there is no OC done....the temp is in the stock condition....
Old 05-11-2007, 06:44 PM   #7 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
clean it blow the dirt out .regurly . this may decreace the temp by 10 degree
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 05-11-2007, 10:03 PM   #8 (permalink)
Use a good quality thermal compound between proccy and heatsink.
Let there be music.....
sashijoseph is offline
Old 06-11-2007, 02:24 AM   #9 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Which cpu do you have? Also mention your whole air circulation system.
john_the_ultimate is offline
CPU Temp 103 C HELP! neel12345 Hardware Q&A 9 20-10-2007 04:04 PM
hdd temp xbonez Hardware Q&A 5 06-04-2007 02:01 PM
High temp sourishzzz1234 Hardware Q&A 7 20-03-2007 12:23 PM
Any S/w That Displays Cpu Temp? return_of_vengeance Hardware Q&A 8 22-09-2006 06:50 PM
Processor Temp dorai QnA (read only) 3 13-11-2004 09:26 PM
- by kool
