04-11-2007, 11:28 PM
We Both Have a Mouse!!!
URGENT GUYS PLS TELL Regarding PSU....
Guys, my psu (which came with my cabinet i ball which was 400watts) suddenly it went off when i was lisning songs, after that my pc refused to start. i suddenly realised that my smps(psu) is dead...
i went rushing to a local computer store to buy a new 1, but all shops were closed
guys now tomoro 1st thing for me is to get a new psu for my pc(under my signature)...
what do u guys suggest???
im getting cooler master 380watts - 2.2k
and cooler master 600watts - 4.2k
i dont want 2 spend sooo much.
which 1 to get?? any other suggestion like zebronics platinum 500watts.
pls tell guys and with price if u can.
P.S. i m getting a new 8600gt or gts very soon...
thanx.
C2D E6750@3.6GHz - XFX 650i Ultra - XFX 8600GT - 2x1 2GB 800MHz JetRam - CoolerMaster eXtreme Power Duo 600W - 750GB HDD - LiteOn LightScribe DVD RW -
HP W1907 19" Wide...
and Altec Lansing ATP3...
04-11-2007, 11:41 PM
Re: URGENT GUYS PLS TELL Regarding PSU....
well, u dnt need much power for a 8600GT. 400W is more than enough. n is the config listed below urs? if yes the, the 380W will do, but gor a reliable brand. Antec, Coolermaster, or u have sum local brands that are trustable like powersafe etc.
04-11-2007, 11:56 PM
thanx 4 ur reply apacheman(and yes thats the config under my sig),
but guys if i want to overclock my c2d like i do most of the time and in future i will get 8800gt then???
and
the price i have quoted of cooler master psu both 380 and 600watts are they fine or more then they should be???
05-11-2007, 12:05 AM
UbuntuUser
Read my signature. I use Amigo 500W PSU and it is working like a charm. Costed me 1800/- tax included from Nehru Place.
05-11-2007, 09:41 AM
thanx cynosure,
but guys i live in bhopal(m.p.) and i dont think Amigo will b avilable here.
the option i have here r
1.Cooler Master
2.maybe Zebronics
3.and all that cheep ones like intex etc...
so guys pls tell fast have to go in 2hrs.
thanx.
05-11-2007, 10:14 AM
UbuntuUser
Cooler Master if you can afford then its the best. It has high efficiency.
Other than that, people here have used zebronics and they have given positive reviews.
05-11-2007, 10:43 AM
thanx cynosure for ur quick reply,
will cooler master 380watts will do with my config but, if i add 8800gt or 8600gts then???
EDIT: i purchased CoolerMaster 600watts for 4k.
thanx every one for ur help.
06-11-2007, 09:21 AM
UbuntuUser
Good choice. 8800 would not have worked with a 380W PSU.
06-11-2007, 09:36 AM
I got Mine for Rs. 450 only. But not much of a known brand. "Odissy" something. Its working fine for my PC. [Refer Sig]
Phenom II 955 BE @ 4.12 Ghz | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Seagate : 1 TB | NZXT Phantom 410
Elite 335 Cabinet @ 0.8K http://www.thinkdigit.com/forum/baza...ite-335-a.html
06-11-2007, 07:25 PM
thanx cynosure for helping me out with this...
just wanted to ask u how much should my psu should have cost coz i think i got it for more than it should be Rs.4000.
thanx again
bye.
06-11-2007, 10:14 PM
UbuntuUser
Nehru Place price was Rs. 3600 when I last inquired about 1.5 months ago. Right now, it should be +/- 500. So considering that other brands are not available at your place very easily, I think 4K is OK.
