Old 04-11-2007, 11:15 AM   #1 (permalink)
Default HDD trouble...plz help
My friend bought following config today
AMD X2 5200+
ASUS M2n-MX SE 8400 for both
Trans DDR2 1GB/667 1100
Seagate 250Gb Sata2 Hdd barracuda 7200.10 2950
iball 400W SMPS 650
old things
Samsung 15" monitor
k/b+mouse
Samsung DVD writer
Cabinet
speakers
Sparkle 7300GS/256Mb Pci-e card
I assembled the cabinet started the PC and asked him to do the partitions and install windows, as he had done it before.
He started with Windows Xp Pro bootable CD, created a 50 GB NTFS c: and finished the installation.
On booting, in Windows, he launched disk management to create another 100 GB partition. While the windows was formatting the partition, he by mistake pressed reset button.
Now nothing is happening..all partitions are gone. Even in Windows setup, we can see 238 GB unallocated free space (whole HDD) but can't create ne partitions.
As soon as we enter the required partition (eg 40000 MB) size and hit enter, the setup comes back to the previous screen, asking to select the setup partition.
PLz help as he as his mom is cursing me for not helping..
sorry for the long post..
Thanks in advance..
bump...
ashnik is offline
Old 04-11-2007, 11:22 AM   #2 (permalink)
dOm1naTOr's Avatar
Default Re: HDD trouble...plz help
Try using Partition Magic to recover the space.
Its better to use Partition magic bootable disk. Orelse try on windows.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 04-11-2007, 11:42 AM   #3 (permalink)
"As soon as we enter the required partition (eg 40000 MB) size and hit enter, the setup comes back to the previous screen, asking to select the setup partition."
windows can't create ne partitions.
i tried Partition Magic 7 bootable CD but even it shows full 238Gb free unallocated space..but shows write, read errors while creating the partitions..even 1GB FAt32 partition is not happening..
ashnik is offline
Old 04-11-2007, 11:46 AM   #4 (permalink)
Ex-KGB
Maybe bring his hard disk over to ur place and format it in Disk Management
EDIT : If nothing else works .. throw the HDD at the service centre
avikchaks is offline
Old 04-11-2007, 11:50 AM   #5 (permalink)
-----ATi-----
nvidia's Avatar
^^ Yes.. This must work. Or try installing some other OS and see if the partition step works..
http://twitter.com/akshayms
nvidia is offline
Old 04-11-2007, 07:05 PM   #6 (permalink)
Thumbs up Re: HDD trouble...plz help
try to use partion magic 8.0 pro bootabe it will help u
raj7000 is offline
Old 05-11-2007, 06:39 PM   #7 (permalink)
try to install any linux os.
thecreativeboy is offline
Old 05-11-2007, 10:09 PM   #8 (permalink)
Get it replaced.......there's no reason why XP setup shouldn't be able to create partitions.
Let there be music.....
sashijoseph is offline
Old 06-11-2007, 07:41 PM   #9 (permalink)
problem solved..
I took the HDD to another friend's place, coz my mobo doesn't have SATA port. and used partition magic 8 in windows.....
Thank u all....from my friend's mom too...
ashnik is offline
help me : i pod trouble dgk.3007 Mobiles and Tablets 6 07-05-2007 07:49 PM
Tv Trouble kichu_overclocked Hardware Q&A 2 27-05-2006 12:32 AM
fat trouble. vignesh Open Source 9 30-10-2005 07:36 AM
Fedora Core 4 installed ...... trouble trouble trouble... iinfi Open Source 19 12-10-2005 06:03 PM
Serious Trouble Help Me!!! superuser QnA (read only) 7 22-02-2005 04:10 AM
- by kool
