Old 03-11-2007, 10:26 PM   #1 (permalink)
manishjha18's Avatar
Default laptop in range of 1200$
my bro wd get a gift from usa-he has to give the model no of any laptop costing not more than 1200$-in usa--
requirement-
240 gb hard disk
2 gb ram
dx 10 graphics card-
vista home premium or ultimate
plz reply within 24 hrs and yes he wont take sony product
manishjha18 is offline
Old 03-11-2007, 10:53 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: laptop in range of 1200$
Dell 1520
Pathik is offline
Old 04-11-2007, 12:06 AM   #3 (permalink)
yeh its great --but it has 160 gb hard disk ok..anyway any other option
any HP option
Old 04-11-2007, 12:44 AM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
Use External USB Hard drives, as that will be more productive that Larger Internal drives
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 04-11-2007, 01:12 AM   #5 (permalink)
cheeta it is a laptop
not a pc-anyway suggest a laptop --leave the hard disk limit
Old 04-11-2007, 01:42 AM   #6 (permalink)
Rebooting
I already did, buy a Notebook like Dell 1520 which will have 160 GB HDD as u are concirn about larger HDD so i suggestedthink of External portable HDDs... as they will offer better productvity than larger Internal inbuilt drives...
Dell 1520 seems a cool option, but as u are buying from USA, do give MACBook a shot... Apple Hadware is damn cheaaap there...
rebooting
ChotoCheeta.com
Old 04-11-2007, 01:55 AM   #7 (permalink)
1.ok if i go for mac which model--but anyway i can install leopard on any laptop and we all love windows
2- any hp model --they have better service at least in no
Old 04-11-2007, 02:23 AM   #8 (permalink)
Rebooting
With student Consession MACBook Pro 15" may come under USD 1200 ... Any Intel MAC will run the new OS without any issue, but I suppose 512 MB RAM would be needed, in case of a New MACBook Pro, u will have 2 GB or RAM, so it will run Leopar with ease...
Now if you dont have Student consesion option, then 13" MACBook will come under that budget !!! it will have 1 GB RAM more than enough to run Leopard...
Both MAC will support bootcamp, which will allow you to run Windows Vista with Leopard in Dual Boot
the New MACBook 13" will have GMA x3100 which i DirectX 10 copmatible with full Vista Aero support
The New MACBook Pro 15" will have dedicated 8600 GT 128MB Card which is also Fully Vista compatible with DX 10
rebooting
ChotoCheeta.com
Old 04-11-2007, 11:00 PM   #9 (permalink)
hey any hp model man-thanks cheeta---hp model
bought dell 1520 -for 48 grands--
damn
Please suggest a laptop in 50 K range... ~Phenom~ Laptops and Netbooks 15 30-10-2007 03:44 PM
Suggest laptop in ~50k range koolbluez Laptops and Netbooks 2 25-08-2007 11:54 PM
Plz suggest me ..which laptop i should buy range 25-30K, maximum 30K arunks Laptops and Netbooks 2 20-08-2007 12:15 AM
sugest laptop in 45-55K range tgpraveen Laptops and Netbooks 3 02-08-2007 11:20 PM
- by kool
