Old 03-11-2007, 12:24 AM   #1 (permalink)
stellar's Avatar
Default DVD Drive Ejection Problem
My DVD Rw(Smasung) drive ejects frequently.It needs a quite a lot pushing too to open the drive too. It makes a certain noise if it is goin to open but after a few toil then only it opens. Suggest opening automatically and hard to open the drive too.
stellar is offline
Old 03-11-2007, 03:59 PM   #2 (permalink)
Default Re: DVD Drive Ejection Problem
Same old Samsung problem! If under warranty, get it replaced.
V.Prem Kumar
janitha is offline
Old 17-11-2007, 04:40 PM   #3 (permalink)
mortal kombat
quan chi's Avatar
i also have similar problems.
quan chi is online now
Old 17-11-2007, 04:46 PM   #4 (permalink)
Cool G5's Avatar
This problem is common with samsung drives.Give it to samsung if it's in warranty else you can't do anything.If you plan to buy a new one get sony or liteon drive.
Cool G5 is offline
Old 17-11-2007, 04:51 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
If it is not under warranty than take it to local service boy..they may charge around Rs. 50-100/- and will fix the problem.
Actually it is problem with ROM pin.
ravi_9793 is offline
Old 17-11-2007, 05:00 PM   #6 (permalink)
Just wondering! If it was so simple to be solved by a service boy, why the HW giant SS is not able to rectify it over all these years?
V.Prem Kumar
janitha is offline
Old 17-11-2007, 05:07 PM   #7 (permalink)
Cool G5's Avatar
They have made improvements in their newer octodrives roms.But still i dont trust samsung drives.
Cool G5 is offline
Old 17-11-2007, 05:42 PM   #8 (permalink)
TechTin.com
ravi_9793's Avatar
I don't know why samsung is not able to solve it........ But it is solved easily by local service boys.Once my friend had same problem, we took it to a local service boy, he repaired it within 15 min and charged Rs. 50/-
Old 17-11-2007, 07:47 PM   #9 (permalink)
Hope such a boy will come to my rescue if needed since I committed the sin of buying a SH-203B one month back. (nothing else was available here then and this model had good reviews and so I took the plunge)
V.Prem Kumar
janitha is offline
Old 22-04-2008, 04:55 PM   #10 (permalink)
Hmm..
I've just ordered a Samsung SH-S203B Drive. Let's see how mine goes.
The GodFather is offline
Old 22-04-2008, 05:34 PM   #11 (permalink)
best of luck to you..if everything is fine..buy a lotto
realdan is offline
Old 25-04-2008, 09:19 PM   #12 (permalink)
what the technique for ejecting the tray....
any guru ....please speak out.....
longlife is offline
Old 25-04-2008, 09:46 PM   #13 (permalink)
there is a tiny hole located on the front facade...insert a pin in it...then pushed it..it will forced the tray to come out a little then you can use your own hand to pull it out of its hiding place
realdan is offline
Old 28-04-2008, 08:39 AM   #14 (permalink)
As it is brand new everything is fine as yet. However, let's see how it goes and time passes.
I had known Tray problems of Samsung CD-ROMs earlier.
DMA Problem on DVD-RW Drive ronweasley Hardware Q&A 2 01-10-2006 06:28 PM
DVD and Cd Drive problem!!!!!!! pranavrahul Hardware Q&A 7 06-01-2006 09:56 PM
CD drive problem m.parthiban QnA (read only) 7 26-09-2005 10:07 PM
USB drive problem. akshar Peripherals 8 16-09-2005 06:01 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
- by kool
