Old 02-11-2007, 11:30 AM   #1 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
Exclamation Is it the problem of RAM?
I bought a 512MB DDR 400Mhz RAM. So, I now have 2x512MB RAM @ 400Mhz, but during the boot, the BIOS shows as 333MHz when running on dual-channel. Running the system on individual module shows as 400MHz. I've got 4 slots on my motherboard and tried all the combinations, but when running on dual-channel, it is underclocked to 333MHz What is the reason?
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
Old 02-11-2007, 11:47 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Is it the problem of RAM?
if possible then please mention the Motherboard model !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 02-11-2007, 11:53 AM   #3 (permalink)
Check the Motherboard manual. It should be containing schematic diagram showing how to install memory to get 400MHz. Different types of memory installed diffrently will yield diffrent speeds.
AMD Phenom II X4 955 BE, Asus M4N98TD EVO, 2x2 GB G.Skill @ 1600MHz, MSI GTX 560Ti Hawk, 500GB Western Digital Black SATA-II, Dell Ultrasharp U2311H, CM 690, Corsair VX550
monkey is offline
Old 02-11-2007, 05:33 PM   #4 (permalink)
phreak0ut's Avatar
I've got a MSI-RS480M2 model. Sorry for not mentioning before. @monkey-I did check out the manual. Even after installing the way they have suggested, I'm getting 333MHz
Old 02-11-2007, 05:55 PM   #5 (permalink)
Fast 'N' Furious
topgear's Avatar
^^^ Update your motherboard's bios to the latest. If possible.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 02-11-2007, 06:14 PM   #6 (permalink)
phreak0ut's Avatar
Wink Re: Is it the problem of RAM?
I've flashed with the latest BIOS.
Old 02-11-2007, 09:12 PM   #7 (permalink)
Rebooting
and ??? Still the problem continues ??
rebooting
ChotoCheeta.com
Old 02-11-2007, 10:02 PM   #8 (permalink)
phreak0ut's Avatar
I had flashed the BIOS almost a week after I bought my system. That was around 2 years back. There are no latest updates on this. So, yes, the problem still exists.
Old 03-11-2007, 04:23 PM   #9 (permalink)
Fast 'N' Furious
topgear's Avatar
Point No: 1 : Are those ram modules from same brand. If not, this could be a latency issue so the mobo limits the speed to maintain stability
Point No: 2 :I think your mobo doesn't supports dual channel ddr upto 400Mhz
instead it supports dual channel mode @ 333Mhz max.
Correct me if I am wrong.....................
topgear is offline
Old 03-11-2007, 10:57 PM   #10 (permalink)
Google Bot
Pathik's Avatar
Check ur ram frequency in the bios.. hav u kept it auto??? change it to 400mhz..
Pathik is offline
Old 04-11-2007, 12:05 PM   #11 (permalink)
phreak0ut's Avatar
Now, there is a BIG problem. I tried to change few things like you guys told and the system refuses to boot. I mean, it switches on, but that's it. Nothing else happens. I changed the Memclock Index Value to 250MHz and left the CAS# Latency(Tcl) to 2.5 (or 3.0 I don't remember properly). The manual says that 3.0 gives the best performance. There is one more thing which I changed. The GFX clock mode. I changed it to Async mode, from Sync. This might be the main cause. I thought that I had fried my RAM modules, but I checked it over at my friend's place and it's fine. Resetting the CMOS jumper to clear the data hasn't helped. Removed the battery to see if it clears the data, that didn't help either. The settings are not falling back to defaults, now what do I do??? It's really urgent! Lot of work pending Oh, BTW, the RAM modules are of different companies. I bought those 'coz I couldn't afford more than that. 1 is a Hynix(I know it can't be called as a brand) and the other is Dynet(there is no Hynix available now in SP Road, Bangalore)
EDIT: Though I can boot my system now, I can't get the RAM to run at 400MHz. I took out the battery for a longer period to clear the setting.
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
- by kool
