I want 2 buy a new pc. Which one would be better for medium gaming as well as for the purpose for learning programming ??? I want a dual core proc....I've heard dat AMD proc's are better than their Pentium counterparts for gaming.... Why's it so ??? Also what is the diffrence between Intel's Pentium D, Celeron D & Core 2 Duo, aren't they all dual core processors ??.....my budget's limited....
Please help me
^^ Xcept tellin that ur bdget is limited tell Xactly wat's ur budget
and purpose:as u told gamin which type of Games and any MM soft's ??
yup AMD is good coz its affordable
and Dual core has 2 cores but core 2 duo has 4 cores iam i Right ?
jus google
