31-10-2007, 06:42 PM
damn busy...
Confused About which psu to buy.help me?
i recently added a 6600GT AGP to my P4 3.06GHz HT system with 1 HDD and 1 ODD and the system refused to boot up.
i think the psu is the problem as my present psu is intex 400W with 55% efficiency .so i wanna upgrade my psu.
which psu to buy for 850Rs Max. colorsit or zebronics?or any other psu.
plz suggest??
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
31-10-2007, 08:59 PM
die blizzard die! D3?
Re: Confused About which psu to buy.help me?
Zebronics 500watt(simple one which comes with zeb cabbys)
or Zebronics platinum 400 watts if it fits your budget.
Stealing your women and horses since 1843.
31-10-2007, 09:20 PM
damn busy...
^^tell the prices so that i can get an idea.
www.techjunkiez.com
31-10-2007, 09:27 PM
ah well prices are highly subjective you see.
Zeb 400 watt----400-500
Zeb 500 watt----600-700
Zeb platinum 400 watt----1200-1400
Zeb platinum 500watt-----1700-1900
Try to get platinum 400watt.
31-10-2007, 09:40 PM
damn busy...
How much power will the simple ZEB 400W psu deliver.
i need atleast 300W power for my components to keep it stable
www.techjunkiez.com
31-10-2007, 10:11 PM
Rising ApocalypsE
Buy a platinum 400W one.....it will give u enough power to run ur system!
01-11-2007, 02:07 PM
damn busy...
efficiency is how much of the 400W platinum and the 12V rail Amperage
www.techjunkiez.com
01-11-2007, 02:10 PM
Google Bot
the platinum shd hav about 80+% efficiency...
or if u want to save money get the normal cheap zebby 500w..
01-11-2007, 02:12 PM
damn busy...
will the normal 500W zebby deliver atleast 350W
www.techjunkiez.com
01-11-2007, 02:21 PM
Google Bot
it shd be able to run ur system easily..
01-11-2007, 02:38 PM
damn busy...
i didn't found the simple 500w psu on their site......
www.techjunkiez.com
01-11-2007, 02:55 PM
Rising ApocalypsE
Buy a 400 W platinum!
U know a good brnaded 500 Watt PSU is better than a cheap 700 watt PSU!
The game is about Ampherage!
01-11-2007, 09:18 PM
damn busy...
but on their site i found the platinum 400W is having 17A on 12V rail but the members told me here that the simple zebronics 400W psu 20+4 pin is having 20A on 12V rail.
i am getting much more confused here
www.techjunkiez.com
02-11-2007, 08:21 PM
Rising ApocalypsE
^^ Can u post some links?
02-11-2007, 09:55 PM
damn busy...
www.techjunkiez.com
02-11-2007, 11:12 PM
@utsav
Zeb normal 400w PSu can't deliver 20A on 12v rail simply coz it dun use such quality components to produce 20A on 12vrail. If it does then it shud generate much heat and there shud have a heavy heatsink inside the PSu. But it dun hafe a heavy heatsink, dat means the transformer inside dat is not dat efficient.
But he platinum series use much more higher quality components. The 400w plat is much heavier than a normal 500w one. So if the platinum says 17A on 12v rail, then it means it cud deliver somewhat close to that. But a normal one cudn't deliver even 60% of what is specified.
G3: XPS M1530 |
FZ 16.
04-11-2007, 04:54 PM
Rising ApocalypsE
Well if u don't trust Zebronics then buy Cooler Master Extreme series...trust me they are really worth it!
04-11-2007, 08:00 PM
damn busy...
^^ havn't u seen my budget.
@ aravind should i buy a 450W colorsit psu for 800Rs
www.techjunkiez.com
04-11-2007, 08:06 PM
#19 (permalink)
Colorsit is better than normal PSU. SO i think a 450w cud handle 8600GT easily.
G3: XPS M1530 |
FZ 16.
04-11-2007, 08:54 PM
#20 (permalink)
damn busy...
^^ i hav 100W power consuming P4 HT and 6600GT AGP with 1HDD and 1DVD-RW and onboard sound and lan.will it be enough
www.techjunkiez.com
04-11-2007, 09:05 PM
#21 (permalink)
Yup, itll be enuf.
G3: XPS M1530 |
FZ 16.
04-11-2007, 10:26 PM
#22 (permalink)
Rising ApocalypsE
Well u require a 400 watt....if Colorsit is 450 Watt and is for 800/- then i must say that it will easily handle even 8800 GTS!
05-11-2007, 01:54 PM
#23 (permalink)
damn busy...
^^ so should i go for 450W colorsit psu with confidence or a zebronics 400W platinum?
www.techjunkiez.com
05-11-2007, 02:33 PM
#24 (permalink)
I didnt check your rig but Zeb 500 platinum is a good buy. I myself bought it about a month and half back for Rs 1850 including all taxes here in Mumbai @ lamington
Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction.
05-11-2007, 10:37 PM
#25 (permalink)
Rising ApocalypsE
Yeah but Colorsit is for 800/- but still zebronics is a worthy PSU.....better than COLORSIT....i believe!
Though its a Chinese PSU but its good and u can see some reviews and ask about the performance from guys who own it!
Acc. to me...this PSU is wicked!!!
06-11-2007, 02:09 PM
#26 (permalink)
damn busy...
^^ which 1 is wicked .colorsit or zebby
www.techjunkiez.com
07-11-2007, 02:09 AM
#27 (permalink)
Rising ApocalypsE
Colorsit..obviously!
Dude don't buy something for which u will cry after u own it!
Buy Zebronics....people know this thing because they know whats exactly it is made up of!
I never go after the first time reviews....although they provide a better idea but i always look for the people who owns it and using it for a quite some time!
Buy Zebronics or the one which has service center in your city!
07-11-2007, 10:22 AM
#28 (permalink)
damn busy...
only intex has service center in my city.i hav to source other psu 's from different cities
www.techjunkiez.com
07-11-2007, 10:44 PM
#29 (permalink)
Rising ApocalypsE
Well in that case i suggest Colorsit is a better option.....atleast better than INTEX.
30-11-2007, 09:56 AM
#30 (permalink)
Cooler Master Extreme 500W Rs. 3600
Cooler Master Extreme 600W Rs. 4600
Thats the quote i got from the only guy who stocks CM PSUs... Way overpriced right?
