Re: URGENT Laptop query
Get the V6608AU. Although the most expensive (from the ones you've mentioned), it does have the best specs from the present lot of entry-level laptops.
Dual core processor, 1gig RAM, 160gigs HDD, .. No reason not to go for it. And it is not as if you're getting an outdated one. The processor and other stuff are very new. And of course, Compaq is a trusted brand. Ask your neighbor/friends/uncles or
all of the above.
Good luck!
