Old 30-10-2007, 12:16 PM   #1 (permalink)
shyamno's Avatar
Default Intel G35 Motherboard ??
Guys...Is there any motherboard currently supporting Intel G35 chipset....???
What is the difference between a P35 and G35 chipset ???
Visit my Blog::::::
http://shyamkol.blogspot.com
shyamno is offline
Old 30-10-2007, 12:19 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Intel G35 Motherboard ??
G35 is not yet available in Mainstream Market Kolkata , hence India... but yes ASUS p35 boards are there
G35 means boards with onboard grfx P35 is stonger between 2 how ever P35 wont come with any onboard grfx !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 30-10-2007, 12:26 PM   #3 (permalink)
shyamno's Avatar
I saw somewhere that G35 chipset doesn't support DDR3 RAM....is it true ??
does both these chipset support the new 45nm technology ???
Visit my Blog::::::
shyamno is offline
Old 31-10-2007, 05:26 AM   #4 (permalink)
Hi Shyam
Asus has just launched two motherboards based on Intel G35 in the international market - Model - P5E-V HDMI and P5E-VM HDMI. I am not sure how long it will take for these motherboards to hit the Indian market,but I guess it will be launched here pretty soon.
I think G35 does not support DDR3.Both G35 and P35 support 45nm processors but might need a BIOS update.But check 45nm support before buying a MB.
Here is a list of motherboards which support 45nm processors - http://www.anandtech.com/mb/showdoc.aspx?i=3138&p=2
nishanth_che is offline
Old 31-10-2007, 03:42 PM   #5 (permalink)
Google Bot
Pathik's Avatar
i think g35 mobos support 45nm proccys out of the box..
btw the onboard gfx of the g35 boards seems to be the best till date..
if they wd hav supported ddr3 then they wd hav rocked...
Pathik is offline
Best Intel Motherboard Udaya Maurya CPU / Motherboards 1 11-09-2007 12:09 PM
Intel e4300 and motherboard? Tooocool Hardware Q&A 11 08-06-2007 01:35 PM
INTEL Motherboard for P4 HT 3.00 GHz under Rs. 7000 bharatesh Hardware Q&A 13 04-02-2007 08:10 PM
WHICH MOTHERBOARD FOR INTEL CELERON 1.1 GHZ. ASH_DSG CPU / Motherboards 2 02-08-2005 08:07 AM
- by kool
