Old 27-10-2007, 11:52 AM   #1 (permalink)
Arrow can PATA connect with SATA
I have an Intl 845 motherboard, with PATA IDE connectors.
Can I connect SATA hard disks and DVD-RW by using SATA to PATA connector?
Pls guys replyyyyyyyyy
ravi.xolve is offline
Old 27-10-2007, 12:30 PM   #2 (permalink)
sachin_kothari's Avatar
Default Re: can PATA connect with SATA
It would be useless to do so (dont know if its pssible).
You will be downgrading SATA speed to PATA speed.
Why spend extra money for SATA drives?
sachin_kothari is offline
Old 27-10-2007, 07:19 PM   #3 (permalink)
Arrow Re: can PATA connect with SATA
SATA drives are cheaper these days. And if I happen to upgrade my whole rig I won't like to dump my drives.
So I feel its always better to use newer technology.
Old 27-10-2007, 07:21 PM   #4 (permalink)
>:)I-):(|)8-X
Charan's Avatar
get your self a SATA PCI card , its about 500 bucks.
http://cgi.ebay.in/PCI-to-SATA-IDE-A...QQcmdZViewItem
i5 2400 | DH67BL | G.Skill Ripjaw 4 GB | FSP SAGA II 500W | CM 430 Black Elite | MSI R6850 Cyclone PE/OC | XBox 360 Controller | 21.5" Samsung Sync Master 2233 | 4 Mbps UL
Charan is online now
pata to sata. sagar_coolx QnA (read only) 5 30-03-2006 06:00 PM
SATA to PATA ra_sriniketan Hardware Q&A 5 27-11-2005 10:43 PM
Sata or Pata ...... What is this. godsownman QnA (read only) 19 10-06-2005 06:41 PM
PATA and SATA tushar_novice QnA (read only) 8 27-03-2005 10:42 AM
SATA YA PATA nishantv2003 QnA (read only) 19 20-10-2004 11:12 AM
