| Forum |
#1 (permalink) |
I am new to digit, few months back I purchased DG101GGc. recently my friend gave me 40GB ( it contains the system file) not sure. after adding it with my 80GB, my system is giving me lot of problems. Now whenever I tried open IE , it reboots in between, running very slowly My system takes 15 min to boot up Normal DVD read/ write opertaion take 160min Guys please help. I am planning to format but getting problem with 120 GB backup.. Is there any way I can add 350 GB with my 80 and 40 GB SATA hard drive Please suggest something
#3 (permalink) | |
No dude, I have scanned my system with McAfee as well with online anti-virus software after disabling system restore. Dear, sorry to be such dumbo man......I am working for McAfee INC. Just get feed up with my 2 hard drive and win XP, can reinstall XP but there is lot of files on disk (B.P Please forgive me, i should mention it in the post. Sorry dude. But thanks for your quick reply |
#4 (permalink) |
try to remove ur friend hard disk and note that comp. becomes normal .if it does than ur friend hard disk may have problem (bad sectors)
yes u can install 350 gb disk provided u have extra cables available ofter attaching 2 disk |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| AMD SELLS INTEL CPUs... HAS IT COMPLETELY LOST THE WAR WITH INTEL C2D | vish786 | Technology News | 9 | 09-06-2007 07:46 AM |
| Intel mobo for Intel Core 2 Duo E6300 !! | kaps_2222 | Hardware Q&A | 3 | 21-04-2007 10:32 AM |
| amd 64 or intel guys ????? | virgin | CPU / Motherboards | 1 | 09-08-2005 11:20 PM |
| Which is best.--->Intel 915P or Intel 915G | vps85 | CPU / Motherboards | 5 | 20-01-2005 08:57 PM |
