Old 25-10-2007, 09:32 PM   #1 (permalink)
Alpha Geek Banned
bikdel's Avatar
Default please, TV tuner query!! its urgent...
Hello guys im in great hurry, just placed the order for
"Pinnacle PCTV pro PCI" which is the Pinnacle TV tuner kit for Windows Vista.
i wanted to know wether this works with my Present Winodws XP Service Pack 2 or not.
Does it have XP drivers too??
Does it some with a media center for XP ??
Otherwise i am doomed,
please guys urgent hel needed...
I'm not a GEEk, i still use Windows!
bikdel is offline
Old 25-10-2007, 09:45 PM   #2 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
Default Re: please, TV tuner query!! its urgent...
I think every TV tuner card that is compatible with Vista is compatible with XP too.
BTW how much you paid for it?
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 25-10-2007, 10:11 PM   #3 (permalink)
Alpha Geek Banned
bikdel's Avatar
^^^ well i paid 2400 rs ...
Will NTSC TV Tuners work here??... with the cable lines im talking about...
do we get PAL to NTSC converters??
the thing is that i actually got it ordered from US....for gods sake, i think i am doomed!!!
bump
bikdel is offline
Old 26-10-2007, 11:11 AM   #4 (permalink)
shadow hunter
vivekbabbudelhi's Avatar
bump
hmm........u did a boo boooo........
in INDIA CATV transmission is in PAL-B standard.
no u wont get any PAL to NTSC converters off shelf here easily
it would have been better if u might have ordered a universal tuner like winfast 2000xp global...btw it retails for rs 2500 here...
knowledge can be shared & must be BUT intelligence CAN'T be
vivekbabbudelhi is offline
Old 26-10-2007, 01:56 PM   #5 (permalink)
Alpha Geek Banned
bikdel's Avatar
^^^ damn i knew it was to happen to me only....
nut hey dude can you tell me one thing....
do TV cards come in different flavours, i mean some for PAL and some for NTSC???
Cuz i went for pinnacle PCTV Pro PCI
url here
http://www.pinnaclesys.com/PublicSit...Analog+Pro+PCI
does that mean that it cannot be used to record from PAL video camera even from the S-Video Jack??..
THREAD ENDING GUYS>>>>>>>>
contacted pinnacle support today,
they said that pinnacle does sell different versions around the globe...
ahh... my money, all wasted.!!!
meaining that the PCTV Pro PCI wont work here.. (
bikdel is offline
Old 26-10-2007, 02:54 PM   #6 (permalink)
Help~Is~Here's Avatar
^^^ Dude, you still santusht with Cable? Thoda aur wish karo, Dish karo
Anyways.. if you get an STB with a connection like Dish or Tata, you can use the SVideo in to watch or record your stuff.. the Svideo has nothing to do with PAL or NTSC.. it's only the analog tuner.. So get yourself Dish or Tata... otherwise there is really no use in having a TV tuner on a computer coz the quality will be pathetic
I've used several TV tuners with both cable and STB and I can tell you that it's only really worth it if you have an STB. And also you're lucky if you get a philips SA713x tuner on this card rather than the normal Conexant these tuner that come with
Help~Is~Here is offline
Old 26-10-2007, 03:39 PM   #7 (permalink)
Alpha Geek Banned
bikdel's Avatar
^^^ well i know it but i wanted it for cable yaar..... ur tata sky remote wont work with Windows Media Center and actually you wont have any use for the card, its PVR software and bundles remote........
for what you say, i could have just bought a capture card man...
correct me if i am wrong
bikdel is offline
Old 26-10-2007, 03:50 PM   #8 (permalink)
Honestly not much use of a remote for the comp except for starting/stopping recording or maybe for radio and pics.
Volume and channel change can always be done on your STB itself.
I guess you should have just gone for a Pinnacle PCTV Pro3. It's a really good card. No degrade in quality while recording even when it doesn't have it's own MPEG encoder.
Old 26-10-2007, 03:54 PM   #9 (permalink)
Alpha Geek Banned
bikdel's Avatar
anyways lookin forward to what i can do...
btw we dont have tata sky and dishtv here..
bikdel is offline
Old 26-10-2007, 03:57 PM   #10 (permalink)
what do you mean you don't have it there? where do you stay? you can get the reception anywhere.. upto the middle east..
Old 26-10-2007, 04:02 PM   #11 (permalink)
Alpha Geek Banned
bikdel's Avatar
not in any other country
not when you are not indian
not when you dont understand hindi well
bikdel is offline
Old 26-10-2007, 04:50 PM   #12 (permalink)
Beware of the innocent
ilugd's Avatar
if you ordered just then, couldn't you just cancel the order? Was it an auction or something?
Life is too short. Have fun.
ilugd is offline
TV Tuner Help!!! Urgent shyam_sukumaran Hardware Q&A 2 13-05-2007 04:35 AM
Which TV TUNER should i buy- URGENT!!! MegaD3th3K Hardware Q&A 7 19-10-2006 08:57 AM
Query for a good TV-Tuner Card....? rajeshgovindan2005 Hardware Q&A 8 04-03-2006 02:07 AM
Which TV tuner card should I buy? {Please It's Very Urgent} aditya1987 QnA (read only) 5 04-07-2005 11:23 AM
