| Forum |
#1 (permalink) |
The Devil's Advocate
my pc just hangs itslef after 4-5 hours of being on coninuously .... the first time i thought it just happened coz of some software malfunction but the sencond and third time i realized that the hdd red light on the cabinet stops responding which i assume is because the hdd stops wrking and hence the pc hangs .... so i hav no clue as to what is wrong .... any ideas
"The problem that shows up with the three red lights on the console is a complex interaction with some very complex parts.” - Robbie Bach http://beingmanan.com twitter: manan | Last.FM: manan |
#3 (permalink) |
"The Cake is a Lie!!"
Suspects:
1. Cables 2. Overheating and Dust 3. Borked Power Supply Open the case and check all the cables
[xubz] ● http://xubz.com/ [steam_id] ● http://steamcommunity.com/id/xubz |
#4 (permalink) |
80 gig - ide and 160gig ide ... the 1 that goes kaput is the 160gig
cables - ithought of that too and have chked that over heating - u can cook omlettes on my hdds (nothing new been so for the past 2 years) Power Supply - possible any way of confirming that
#5 (permalink) |
die blizzard die! D3?
power supply:I don't think so cos who were using it before cleaning and it was workig all right.
cables:interchange 80gigs and 160gigs cables abd see what happens....it will locate the source of problem. overheating:get a cheap big cabinet and some big noisy 120mm fans.total damages-not more than 1.5k.
Stealing your women and horses since 1843. |
#6 (permalink) |
the fans wont have much of difference as the cabinet is in a "cave" .... i will try interchanging the cables
#7 (permalink) |
^^yea do that.If 160 gigs stop working then its a problem with it if 80gigs stop working then its a problem with cables\power supply.
#8 (permalink) |
>:)I-):(|)8-X
Even I have a similar problem, but I realised it was not the hdd. first 1 hr there will be no problem. but once the system starts to hang... then after every 10-15 minutes
i5 2400 | DH67BL | G.Skill Ripjaw 4 GB | FSP SAGA II 500W | CM 430 Black Elite | MSI R6850 Cyclone PE/OC | XBox 360 Controller | 21.5" Samsung Sync Master 2233 | 4 Mbps UL |
#9 (permalink) |
IO chip
#10 (permalink) |
>:)I-):(|)8-X
na not the HDD IO chip , the motherboard IO .. thats what he said... he he , I cant recall if northbridge or southbridge is the IO chio
#11 (permalink) |
even if mobo io chip gone means new mobo ...
#12 (permalink) |
>:)I-):(|)8-X
^^^ my mobo got 2 more months warranty
#13 (permalink) |
i think iv narrrowed down the problem to the psu .... today morning the pc hung as expected tried to restart it but the monitor light would simply blink with dvd rom working and mostly the hdds werent working tried re-starting a couple of times didnt work interchanged the dvd and hdd cables the pc booted till the boot screen and hung while loading the os then again the first problem monitor kept on blinking .... so fiddled with the power connectors and it worked for sometime ... its on now lets c how long .... but i guess im getting a new psu for my comp ... been along time since it got something new
#15 (permalink) |
>:)I-):(|)8-X
My case is also quite similar to iMav's ... now its not booting at all. Lets see what the technician tells
#16 (permalink) |
Update: new psu problem solved
#17 (permalink) |
>:)I-):(|)8-X
^^ My PC is still dead.. Hope fully that technician will come tmro and fix my issue
#18 (permalink) | |
"The Gentleman"
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense." - Dijkstra |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| 48 Hours of Down time ?? | Choto Cheeta | Chit-Chat | 29 | 25-05-2007 10:00 PM |
| Orkut Down For 13+ Hours | shankar_ganesh | Technology News | 41 | 02-01-2007 08:33 PM |
| HAPPY HOURS FOR SANCHARNET??? | rajas700 | QnA (read only) | 9 | 11-09-2005 12:29 PM |
| Internet Hours Measuring | Gaurav | Internet & WWW | 3 | 23-05-2005 10:54 PM |
