Old 24-10-2007, 07:35 PM   #1 (permalink)
Default USB PORT NOT responding
My OS is Xp sp2 USB port work normal
and also inserting Pen drive it work also normal
but once to insert pen dirve it asking to use USB 2.0 for working fast
Un-willing i click ok, after that my usb port not responding.
Massage: Please install USB installer.
avidasioc is offline
Old 24-10-2007, 07:42 PM   #2 (permalink)
Dreamweaver
Gigacore's Avatar
Default Re: USB PORT NOT responding
it looks like your USB drivers are corrupted! IF you have the USB 2.0 drivers in ur motherboard CD install it. . . else download from internet . . . and make sure even ur USB controllers and enabled in ur BIOS . . .
BTW, is it Massage or Message ?
Gigacore is offline
Old 24-10-2007, 07:59 PM   #3 (permalink)
anand1's Avatar
Yes it seems youe USB device has been corrupted. Have a new USB port in just 10 or 20 RS and plug it externally and install the USB 2.0 driver as well. it will work for you.
Technology On The Fly
anand1 is offline
Old 24-10-2007, 08:07 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
I am not getting ur problem exactly...........
Please explain in detail...
www.9zap.com/forums -> Indian Webmaster Forum
whost.in - Web Hosting Offers
thinkdigit.com/forum/showthread.php?t=109137
TechTin.com
ravi_9793 is offline
Old 24-10-2007, 10:30 PM   #5 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
Duh that is because your pendrive is USB2.0 and the port you are using is USB1.1 so try using some other usb port if you think your mobo has usb2.0 ports .But even a usb2.0 pendrive should work with a usb1.1 port albeit at lower speeds.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
not Responding JohnephSi Mobiles and Tablets 1 19-06-2007 01:50 PM
DVD ROM not responding ritish Hardware Q&A 3 20-05-2007 11:06 AM
DVD not responding coolsunny QnA (read only) 5 17-08-2006 01:57 PM
Broadband Modem: One USB port to Two USB port ajinkyakulkarni87 Hardware Q&A 3 03-08-2006 09:56 AM
