| Forum |
LinkBack (2) | Thread Tools | Display Modes |
#1 (permalink) |
a_g = JPKN
tried google, but couldnt find drivers, the brand "Enter" itself is not found so can someone upload the drivers.
★----------�----------★ _ ★----------�----------★ |
#3 (permalink) |
^^ +1.. try BlueSoleil .. they mostly work wid all dongles!!
C2D E8400, MSI P45 Neo-F, Sapphire HD4850, Dell 2409W, OCZ 2*1GB RAM + 1*2GB Transcend + 1*1GB Transcend , Seagate 1TB + 2*Seagate 80GB, 600W SMPS, APC 600VA, Creative EP630, Sennheiser HD202 |
#10 (permalink) |
so... it worked???
#12 (permalink) | |
a_g = JPKN
i went for dinner ============= btw its not working shows this error - ... whe i try to turn it ON frm taskbar ![]() Device Mngr. pic. ![]() When i insert the dongle, it shows up in Device Mngr., but after 20 seconds it dissappears wit a pop up balloon, saying BlueTooth Device removed
★----------�----------★ _ ★----------�----------★ Last edited by s18000rpm; 23-10-2007 at 11:21 PM. Reason: Automerged Doublepost |
#13 (permalink) |
The High 5 Flyer
Hey RPM long time no see........sorry I forgot your proper name....but nice to see you again.......even I was out for quite a long time........
So you are trying to use bluesoil. Even I used BlueSoil for some time but I guess the s/w Bluesoil is not free and so recently I started getting the message that you can only transfer less than 5 MB of file. I dropped Bluesoil from there after. Instead the best way I found was to use the inbuilt windows bluetooth drives. Your XP Should be able to detect the device and install the drivers once it is plugged in. My XP64 SP1 detected it successly and installed the drivers. Once the drivers are installed it would say the usual "device is installed and ready to use" thing But make sure that thet bluesoil is NOT running when you plug in the device, other wise windows would not detect and install the drivers. If the drives r successfully installed you should see a blue bluetooth icon in the task bar. If you do not........ you can find the same in the network connections in CP. Now doubleclick the blue icon you should see the bluetooth devices window. Below is a screen shot along with the device manager screen. Note there are no devices. ![]() Click on add and the add new bluetooth wizard will start. ![]() If the device is on it should be detected... ![]() Put a passkey if you want to....click on nect ![]() Your mobile would ask to enter the same passkey......once done the devices will be paired. and now you should see the device in the bluetooth devices window....click ok to close the window. ![]() Now comes a bit tricky part. Once everything is done you would ask how am I suppose to transfer files. Even if you do find your computer in your mobile while doing a device search you still wont be able to send files. For that your computer needs to be in the recieving mode......for tha right click the blue icon at the task bar and opt "Recieve a file". You computer is now ready to accept files. ![]() Now when you would search your computer through your mobile you should be able to see it. You simply send any file using send via bluetooth and your computer should start recieving the file ![]() In the end it would ask you where to save the file. ![]() Once the path is given the file will be saved to your selected location............ Enjoy.... ![]() Hope this helps....... |
#14 (permalink) |
a_g = JPKN
yeah, its been very long time
btw Thanks buddy, very nice tut. but before gettig the BlueSoleil, i tried XP itself, but it didnt install the drivers i'll try it again if this s/w still doesnt work. btw the Bluesoliel we get with the dongle was free, it didnt restrict such transfer limits. can someone upload the full version of s/w which comes with "Enter Bluetooth Dongle".
#15 (permalink) |
Scan using http://driveragent.com/?PHPSESSID=ip...2tgs78bmu4v7b0
You may get it there after scanning.
Kiran Kumar R |
#16 (permalink) |
Back in Power
@rpm
U need to update driver after installation from device manger while installing driver for the first ,dont insert the dongle while installation after installation restart the pc and enter(enter and update driver from device manager.... choose install from a list or specific location (advance) then choose dont detect i will choose the driver to install and from list choose driver and install now restart again Hope it work now
¡uʍop ǝpısdn ɹoʇıuoɯ ʎɯ pǝuɹnʇ oɥʍ ¡ʎǝɥ |
#17 (permalink) | |
The High 5 Flyer
I am not sure why my blue soil s/w have started giving that stupid transfer limit if its free....... |
#18 (permalink) |
Back in Power
which version recently u r using now sam9s?
only 1.4 version comes free with dongles new version has 5 mb limit and its paid one....
#19 (permalink) | |
a_g = JPKN
when i try to update/install driver in XP With the Bluesoleil s/w installed I get Code 10 & 40 as errors i tried with version 2.3 standard, v5.0, v5.0.5, but all of them return same error that is Bluetooth works for sometime & disappears from Device Mngr. when it works, i try to search for "Device" from my Cousin's mobile (SE W300i), it says no device found, same from the s/w side Quote:
★----------�----------★ _ ★----------�----------★ Last edited by s18000rpm; 24-10-2007 at 02:25 PM. Reason: Automerged Doublepost |
#20 (permalink) |
Back in Power
Then may be some hardware problem i think
its very simple to install and use it and rpm ur post count shows u r not a noob so dere is no point on telling how to install or what are basics I use enter dongle with bluesoleil since 2 yrs with no problem only for first time i ve to update drivers manualy try with another dongle
#21 (permalink) | |
a_g = JPKN
can you upload that s/w which came on Driver CD.
or give me a link for that v1.2 of it. the dongle was working fine, before the XP SP2 re-install. Quote:
i'll try again after 9pm (free d/l hours)
★----------�----------★ _ ★----------�----------★ Last edited by s18000rpm; 24-10-2007 at 02:33 PM. Reason: Automerged Doublepost |
#23 (permalink) |
a_g = JPKN
dude, i know how to do that^ . dunno why it didnt list any drivers at first, but i reinstalled v5.0.5 & then it showed, & got installed. but same problem. this thing works for a while (LED ON on dongle), then after 30sec. - 1min turns OFF. what i observed is, it turns OFF like that only when BlueSoleil is installed but keeps blinking when no s/w is installed
#24 (permalink) |
Back in Power
Strange problem :s
never faced such issue in these 2 yrs of my usage uninstall driver completly run ccleaner and reboot install again(without inserting dongle) reboot now insert dongle and update driver manualy reboot don let the services start before reboot (check ur pm)
#25 (permalink) |
a_g = JPKN
i guess moisture has done some damage .
i'll buy new Dongle (as i too need it rit now after opening the Dongle case, i did some "filing" anyways i'll give you guys the feedback in two days. & Thanks a lot for all the Help.
#26 (permalink) | ||
The High 5 Flyer
Code 40 ..."Windows cannot access this hardware because its service key information in the registry is missing or recorded incorrectly".. But basically I presume your dongle has gone bad.......replace and then try....... Quote:
sam9s NAS Project! powered by Unraid! (Corrected!) sam9s HTPC Project! powered by XBMC! sam9s i7 Powered by Sandybridge! My XBMC Collection Last edited by sam9s; 25-10-2007 at 02:38 AM. Reason: Automerged Doublepost |
#27 (permalink) |
a_g = JPKN
oops, i forgot to tell you guys, the dongle was the culprit.
bought new one, its working fine (with BlueSoleil s/w). Thanks Guys.
#29 (permalink) | |
The High 5 Flyer
Thats what I said......... |
#30 (permalink) |
I have the cd with me buyed today. If needed mail me 123starweb@gmail.com
| Bookmarks |
| Thread Tools | |
| Display Modes | |
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/71384-request-enter-bluetooth-dongle-driver.html
| Posted By | For | Type | Date | |
| Thread WANT to Buy Bluetooth 3.0 dongle for PC | Digit Forum | BoardReader | This thread | Refback | 03-08-2011 12:11 AM | |
| Thread Techcom Bluetooth Dongle not working !! | Digit Forum | BoardReader | This thread | Refback | 20-05-2011 05:58 PM | |
| What Bluetooth Dongle??? | linardni | Mobiles and Tablets | 11 | 29-07-2009 06:26 PM |
| enter bluetooth dongle | viruses | Mobiles and Tablets | 15 | 17-07-2008 09:03 AM |
| Bluetooth USB Dongle | GeekyBoy | Peripherals | 1 | 31-12-2006 01:11 PM |
| wifi using bluetooth dongle... | anilthomas26 | Hardware Q&A | 7 | 18-11-2006 12:58 PM |
| Bluetooth USB dongle | Devrath.N.D | Hardware Q&A | 2 | 28-06-2006 06:44 PM |
