Old 23-10-2007, 08:48 PM   #1 (permalink)
Alpha Geek Banned
bikdel's Avatar
Default how to connect CRT to 6800 extreme?
hi guys....
just got my friends XFX 6800 Extreme 256 MB
took it from him for 1 month and gave him fx 5200.. lolz
anyways, the thing is that he had an lcd n i have a 17" CRT
but as soon as i got the card, to my surprise, i had a Dual DVI and S Video...
NO VGA???...
now how do i connect my CRT to the DVI port??
is it possible to use any converter??
I'm not a GEEk, i still use Windows!
bikdel is offline
Old 23-10-2007, 08:52 PM   #2 (permalink)
-----ATi-----
nvidia's Avatar
Default Re: how to connect CRT to 6800 extreme?
yes you can get DVI to VGA adapter. you can get it for under 100 bucks i think.
nvidia is offline
Old 23-10-2007, 08:55 PM   #3 (permalink)
sam_1710's Avatar
yup.. its possible using a DVI to VGA convertor
Its usually bundled with Graphic cards.. but u can buy them separately for some 250 bucks or so!!
C2D E8400, MSI P45 Neo-F, Sapphire HD4850, Dell 2409W, OCZ 2*1GB RAM + 1*2GB Transcend + 1*1GB Transcend , Seagate 1TB + 2*Seagate 80GB, 600W SMPS, APC 600VA, Creative EP630, Sennheiser HD202
sam_1710 is offline
Old 23-10-2007, 08:57 PM   #4 (permalink)
Alpha Geek Banned
bikdel's Avatar
woooow......... man... didnt know it........... we get that for both ways??
i mean from DVI-VGA n VGA-DVI???
bikdel is offline
Old 23-10-2007, 08:58 PM   #5 (permalink)
-----ATi-----
nvidia's Avatar
Ask your friend if its bundled with the Gfx Card... He'll have it i think...
nvidia is offline
Old 23-10-2007, 09:05 PM   #6 (permalink)
Alpha Geek Banned
bikdel's Avatar
okay... thnx for that info.....
BTW
@ whots the retail price of the above card??.... maybe i'll buy the same...
needed to play bioshock desperately!!
bikdel is offline
Old 23-10-2007, 11:19 PM   #7 (permalink)
assasin's Avatar
^^^ if u wanna buy a new agp card,better get a 7600GT
assasin is offline
Old 24-10-2007, 09:41 PM   #8 (permalink)
Alpha Geek Banned
bikdel's Avatar
^^^ not for my dyin PC dude....
would get anything having sm 3.0.... something of the 6600 kind maybe...
i wont spend much on this
"Intel Celeron D 2.4 Ghd, 533 Mhz FSB, 256 KB L2
1 GB DDR 400
160 GB SATA II HDD working on SATA I MOBO
Nvidia Geforce FX 5200 128 MB"
bikdel is offline
Old 24-10-2007, 09:47 PM   #9 (permalink)
shadow hunter
vivekbabbudelhi's Avatar
beware DVI-D cannot be converted to RGB or analog VGA .
knowledge can be shared & must be BUT intelligence CAN'T be
vivekbabbudelhi is offline
Old 24-10-2007, 09:49 PM   #10 (permalink)
dOm1naTOr's Avatar
@bikdel
6600 is out of production. As u want an AGP solution , the best deal is 7600GT for 6k[GP] or 7600GS for 4.5k~5k[AGP].
The 7600GT cud give more performance than 6800 Extreme or Ultra in todays games.
Or u can also have ATI X1600 Pro or XT AGP.
@vivekbabbudelhi
nup dude. It can be done via the adapter dat sam said. But the other way is not possible[If i remember]. U cannot convert D sub analog to DVI digital via ny adapters.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 24-10-2007, 10:05 PM   #11 (permalink)
shadow hunter
^^dvi-i carries both analog & digital
dvi-d just has digital
so dvi-i can be converted to rgb with just a plug
http://www.projectorpeople.com/cable...onnections.asp
http://www.dell.com/content/topics/g...=gen&~lt=popup
Old 24-10-2007, 10:07 PM   #12 (permalink)
Alpha Geek Banned
bikdel's Avatar
u mean to say 7600 Gt/GS is in production??... no way man... jus the left over stock is there i gues...
and why cannot one go for DX 10 cards, i mean if someone has pretty decent config and just wants wants prformance from the ageing AGP bus because upgrade would come at a higher cost, then:
then one can opt for HD 2400 or 2600 AGP, isnt it... so better performance in vista as well...
and AFAIK HD 2600 performs better than 7600 GT
bikdel is offline
Old 24-10-2007, 10:16 PM   #13 (permalink)
dOm1naTOr's Avatar
I dun think HD 2600 is available in AGP. Also there are no GF8 AGP cards out.
So considering that, the better deal is GF7 cards.
G3: XPS M1530 |
FZ 16.
Old 25-10-2007, 03:27 PM   #14 (permalink)
Alpha Geek Banned
bikdel's Avatar
they are available dude.... i checked them out...
but possibly not anywhere in this region...
heres the link
http://www.tigerdirect.com/applicati...5153&CatId=318
bikdel is offline
Old 26-10-2007, 07:00 PM   #15 (permalink)
Maximum Fame
quadroplex780's Avatar
Yes u can get a sapphire ati radeon HD2600 for AGP
-http://www.sapphiretech.com/us/produ...cts.php?pcat=3
u can also get a Gecube one.
ASUS P5N32E-SLI,XFX 8800GTS 640MB SLI,Intel Core 2 Duo E6600 Oced @3.01Ghz,Thermalright Ultra 120eXtreme,Corsair HX-620W PSU,250 GB Sata Seagate & Sony Sata AWG170S DVD writer,Asus Supreme FX Audio.
quadroplex780 is offline
Can I connect 2 internet connections Connect at a time? gaju6696 Internet & WWW 6 06-02-2009 08:26 PM
6800 or 6600gt sanchit324 QnA (read only) 7 11-05-2007 02:18 PM
About 6800 Geforce viki Hardware Q&A 2 21-02-2007 11:13 PM
FX 6800- two molex ? gsoul2soul Hardware Q&A 19 21-09-2006 09:06 PM
Query about 6800 XT killzone Hardware Q&A 5 16-08-2006 09:35 AM
