Old 22-10-2007, 09:37 PM   #1 (permalink)
Default Monitor Blackout
from past few days my monitor (LG Studioworks 563N) has been behaving strangely.after i turn it on and use it for sometime say half and hour or so the screen starts to either flicker or there is a blackout i.e. my monitor gets turned off but if u wack it gently on its side the screen comes to display.i have checked the power options and cleaned the power cables.but still the problem persists can any of u lead me out of this weird problem.Looking forward to u all for help.
ivanpatro2000 is offline
Old 22-10-2007, 09:48 PM   #2 (permalink)
anand1's Avatar
Default Re: Monitor Blackout
There might be a problem of stray Electric Field around ur Room where you use your PC. Notice that near your Room no High Voltage Electric Transmission line goes.
Technology On The Fly
anand1 is offline
Old 22-10-2007, 11:40 PM   #3 (permalink)
i had the same problem, got it solved by LG tech support free as my monitor was under guarantee
What the guy did was to resolder some worn out joints at the discharge tube PCB.
Faun is online now
Old 23-10-2007, 12:27 AM   #4 (permalink)
thank u for ur help and support.
15' monitor lcd.plz help!! ssk_the_gr8 Hardware Q&A 18 13-03-2007 08:50 PM
Monitor as TV wirelessraj Hardware Q&A 3 05-10-2006 06:36 PM
Monitor and Monitor Power Light is blinking aathif QnA (read only) 4 21-05-2005 05:20 PM
Which is the best 17'' monitor? hafees QnA (read only) 14 23-01-2005 05:16 PM
- by kool
