Originally Posted by utsav
the card fan is working and its LEDs r also working but the card isnt.should i disable the onboard gfx by setting the shared memory to zero
Hmm that rules out the power issue i think !
Ok as a last resort do this step by step...
1.Enter your bios via onboard gfx and Set you agp apperture size to 64 MB
2.Disable the onboard video card and set the shared memory to zero !
3.Set AGP as your primary display
4.There should be a settings in the bios to clear ESCD ..enable that for next reboot
5.Now shut down the pc completely
6.Disconnect the power
7.
Remove any PCI card such as modem,lan card etc
8.clean the golden contacts of your card as well as the AGP slot
9.Now insert the card in the slot and lock it firmly.
10.now connect the cables and start the machine..the machine should start.If it is not starting and some beeps coming out of the system then your card must be faulty.
Go ahead..best of luk
BTW After disabling the onboard video you wont be able to use it untill you reset the bios again.To do that either use Clear CMOS jumpers in your mother board (Refer to you mobo manual) or remove the battery for 5 minutes then again insert it and start.
