I recently tried to use my DVD/CD Rom drive and it isn't working properly. I pulled up the device manager and it said:
This device cannot start. (Code 10)
Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available.
I clicked on the 'Check for solutions' button and it searches for about 15 seconds and then it just disappears.
Last thing i did before the problem is using MagicISO to mount an image on virtual CDROM ! ( I realy think it was the reason )
I have Uninstall MagicISO but the problem doesn't gone !
Any suggestions?
