Originally Posted by sourav
i am think of buying a wireless router and i want its cost to be as low as posible, and it must be less than 2000 rs.
Think about DSL modem cum router
What is the range does it provide?
Cant say exact range.But will work fine for home use.
Does any of those provide two-three ethernet ports as it is important for me.
As my pc and bsnl modem should directly connect to it through it and should have a extra port for connecting one more computer to it through ethernet.
I have seen wireless modem cum router at Airtel BB.They provide BX440 modem, it has 4 ethernet port.
How many wireless devices can be connected in parallel??
Airtel BX440 modem can be used to connect 12 wireless system and 4 system with LAN.All 16 systems can work simultaneously.
with increase in connection does the speed decrease only decrease if no one would be using except two people.
Speed will depend on number of PC sharing internet.
my house is about 1500-2000 sq feet with 2 floors. Will it be able to give connectivity to all the corners of the house
yes, it will work fine.I have seen Beetal BX 440 modem, it works fine in 2 floor building.
Originally Posted by Charan
Actually im against going for a Modem cum router, specially BSNL wifi modem, cause if I change my service provider then I "may" have to change the modem also.
you don't need to change your modem , if you are with DSL technology.Airtel, BSNL, MTNL ..all work on DSL technology.
One more thing is that I may have to place the router at a centeral location rather than near my computer.
you dont need to put router in center.Modem-cum-router can be placed anywhere, making sure it is in range.
