22-10-2007, 11:28 AM
memory upgrade for Intel 845GLAD motherboard
hai,
I have an Intel 845GLAD motherboard,i have 256 MB ram (pc2100 ,266mhz),
I want to upgrade it to 1GB ram.The 266mhz is not avaliable. is it possible to use 333mhz or higher ram on this motherboard ?
does 266mhz ram is available in kerala(in cochin)?
Thanks
Sree
22-10-2007, 11:49 AM
TechTin.com
Re: memory upgrade for Intel 845GLAD motherboard
you can use 333Mhz RAM chip.
But it will work at 266Mhz speed only.The higher frequency RAM will underclock automatically to match lower frequency .
22-10-2007, 11:57 AM
Rising ApocalypsE
Your motherboard supports only PC2100, PC1600.....too bad.....try find it in ur local market or post in Bazaar section!
22-10-2007, 12:23 PM
Does it cause any problem to motherboard or performance?
My motherboard FSB is 400MHz.
22-10-2007, 01:31 PM
Rising ApocalypsE
Thats ur CPU frequency but ur memory only supports only PC 1600 and PC 2100 which is 200 MHz and 266 MHz frequency respectively!
22-10-2007, 02:49 PM
TechTin.com
It should not.........but before buying just give a try.
your RAM frequency will underclock to your old RAM frequency.Thus it will work at lower frequency only.
22-10-2007, 09:22 PM
try finding RAMs from same manufacturer..it will help to avoid conflict
22-10-2007, 10:13 PM
TechTin.com
manufacturer dont matter, but frequency matter.
22-10-2007, 11:25 PM
Alpha Geek Banned
IMO....
if you can then sell off the 256 mb ram u have , and...
get any 1 GB DDR RAM u can find, be it DDR 400 or lower...
it will work in your pc ...
I'm not a GEEk, i still use Windows!
23-10-2007, 06:25 AM
Gizmo Freak !
Nopes...Sidewinder was right.Manufacturer do matter ! As the same manufacturer will probably use same kind of ram chips in its productline it will help to avoid conflict !
When you are mixing RAMs of different frequency it is always advisable to go for the same manufacturer !
23-10-2007, 08:52 AM
TechTin.com
There are some standards..and all companies follow it.So, company doesn't matter.
