Old 20-10-2007, 07:09 PM   #1 (permalink)
Default Suggestion for desktop replacement Laptop
Hello friends,
I have a idea of buying a laptop. I am looking for a desktop replacing laptop... My budget is upto Rs.80,000... I will use that laptop for
1. Learning Programming
2. Multimedia
3. Using External TV tuner, I will watch TV
4. Playing Games
5. Surfing,etc
Please Suggest a Good Configuration...
Thanks in Advance....
sakthirajesh is offline
Old 21-10-2007, 10:10 PM   #2 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
Default Re: Suggestion for desktop replacement Laptop
go for dell 1520 highest config or dell 1720
n00b forever...
~Phenom~ is offline
Old 21-10-2007, 11:07 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
Dell Inspiron(TM) 1720 Notebook
price 67.5K
After that customize as much as you can invest.
check www.dell.co.in
ravi_9793 is offline
Old 23-10-2007, 10:54 PM   #4 (permalink)
Thank you guys..
Old 23-10-2007, 11:00 PM   #5 (permalink)
Rebooting
Choto Cheeta's Avatar
Dell 1520 with 8600 GT and 2 GB RAM and a better upgrade on the processor !!! it should take the price at Rs. 60k then i would say buy one Large TFT as Dell 22" E228WFP which would be around Rs. 15k all... and rest 5k can be used for wireless external keyboard and mouse...
so at home, enjoy the bigger screen with wireless external keyboard and mouse but when going out just take the Lappy it with you self
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 23-10-2007, 11:07 PM   #6 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
^^What an iDEA Sir Ji.
An iDEA can change ur life. ho ho ho ....ho ho ho....
lol . reminded of idea ad.
n00b forever...
~Phenom~ is offline
Old 31-10-2007, 09:32 PM   #7 (permalink)
Thanks for your Idea....
Planing to buy a new desktop...need suggestion Abhishek Dwivedi Hardware Q&A 4 15-10-2007 07:54 PM
Suggestion and some doubts for a Multimedia Laptop drgrudge Laptops and Netbooks 88 29-08-2007 10:18 AM
laptop suggestion iMav Laptops and Netbooks 34 07-08-2007 12:52 AM
Suggestion needed - desktop or lappy Kalyan Hardware Q&A 13 12-05-2007 12:14 AM
suggestion for a laptop deepkumar Laptops and Netbooks 2 22-07-2006 03:45 PM
- by kool
