Old 19-10-2007, 09:46 AM   #1 (permalink)
Default Ram ??
Hi to all....
I have bought 1GB of RAM Transcend jetram 512MBx2 for 1350/- for each module....
I have twinMOS 256 mB existing module DDR400 RAM....
if i use all togather will it work and give me full performance....or not??
or should i use only 1 GB of ram..??
I am normal gamer....usualyy play carbon, mostwanted and GTA sanandreas...quiet a lot...nice performance after i installled 1 GB of RAm....
but is there anee need for grafix card now....??
I chked out prices of XFX 8600GT 256MB DDR3 ==> 5800/-
512MB DDR3==> 6800/-
Should i go for same?? what will be performance is it speed?? or visual?? or other than this?
prafulltcs is offline
Old 19-10-2007, 02:45 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Ram ??
you can use all 3 RAM , but remember all 3 RAMs should be of same frequency and type(DDR, DDR2).
Adding a graphics card is good idea.But only if you have money and can't play some games.
ravi_9793 is offline
- by kool
