Old 18-10-2007, 04:14 PM   #1 (permalink)
Aditya11's Avatar
Default Cant Burn DVD's on LG Drive!
Hi guys,
I upgraded my pc a week ago and since then I am unable to write any dvd's! I can READ CD/DVD but unable to WRITE anything. I was using Nero 7 Ultra and even tried Deep Burner and in both cases whenever I click on the "Burn" button, the green light on the DVD writer flashes, no hdd activity and the dvd-drive makes faint noise as if dvd is spinning against something...my pc hangs after 2-3 minutes.
DVD Writer model number: HL-DT-ST DVDRAM GSA-H12N (LG Brand)
I upgraded the firmware, but it didnt help either.
My System config is as below:
ASUS M2A-VM HDMI Mobo
1 GB DDR2 RAM
8600GTS 256MB
80GB HDD (IDE)
Before upgrading I could write CD/DVD without any propblem...dont know whats the problem now...can anyone help?
Thanks in advance.
Aditya11 is offline
Old 18-10-2007, 06:37 PM   #2 (permalink)
Default Re: Cant Burn DVD's on LG Drive!
Use a lens cleaner cd and try burning with a different-brand dvd.Also check the dma status of your writer.
Whic psu are you using?
sashijoseph is offline
Old 18-10-2007, 07:19 PM   #3 (permalink)
what exactly did you upgrade?
casual_gamer is offline
Old 18-10-2007, 09:27 PM   #4 (permalink)
Aditya11's Avatar
I have been experimenting with various DMA settings with 40/80 conductor IDE Cable. Since I do not have SATA HDD, a single IDE Cable supports both hdd (master) and dvd-writer (slave). My Mobo supports UDMA mode but apprently my dvd write has problems with that. I disabled UDMA for 1. DVD-Write 2. HDD 3. BOTH, thru BIOS and its giving me confusing results. I CAN write DVD when BOTH writer and hdd udma mode are disabled (and are on multi-word DMA mode), but its taking ATROCIOUSLY long time (THREE TIMES longer than before for standard 4.7GB DVD). And even then, at one time it would write while another time it wont until I restart system! This is so strange and confusing.
My PSU is Powersafe Gold 400W.
The Firmware. Try Googling with model number and you should get it.
Aditya11 is offline
Old 18-10-2007, 10:10 PM   #5 (permalink)
but here you say
Hi guys,
Anyway, if your motherboard is has Intel chipset then install "Intel Application Accelerator", this software will automatically enable DMA and will speed up your pc. It might solve your DMA problems, try it.
Old 18-10-2007, 10:28 PM   #6 (permalink)
Aditya11's Avatar
Seems I was not clear about "upgrade" thing. I upgraded my SYSTEM a week back (without dvd-writer) but seeing that DVD-Writer developed problem AFTER the upgrade, I downloaded the latest firmware and applied it, which didnt solve the problem. Hope that clears the case.
I have AMD Motherboard, which has ATI drivers for mobo chipset so no Intel s/w for me!
Aditya11 is offline
burn iso on pen drive vinit suri QnA (read only) 14 10-09-2009 08:56 PM
Unable to burn DVD'S Lakshmi kanth Software Q&A 14 18-08-2007 04:08 PM
Combo drive LG GCC 4522B doesn't read DVD's dabster Hardware Q&A 4 06-04-2007 12:25 PM
Combo drive does not burn at the max speed VD17 Hardware Q&A 3 03-01-2006 01:20 PM
DVD drive doesnt open DVD's devil666 QnA (read only) 16 24-09-2004 11:54 AM
- by kool
